Rebel only tire size referral
limechallenger
Ok , so I've searched and searched this forum for a clean answer ,and most threads go off point very quickly! What I'm trying to find is advice on maximum tire size that will fit a STOCK NON AIR SUPENSION 2020 REBEL. My factory Dura tracs are about done, and I want to put the tallest, widest all terrain tire on without needing to level or lift my truck. Please only respond if you have a Rebel!
Thanks!
Dewey
WI
I have 295/70-18 on mine with ORG. Just over 34”. All stock and zero rubbing anywhere. I was told that those are the max size with 1” raised height on the ORG especially if you do any off-roading.
Howardlv22
I have a 24 Rebel and I did the heat gun trick to push out the wheel liners and 35”s fit perfectly t zero rubbing. I do have a level and -12 offset on my method 305’s but the level didn’t help the bigger tires the wheel well liner trick did.
AV41Medic
Just bought a new Rebel GT. Upgraded to BFG ATKO 295/70. Dealer mechanics said it was the max size for a stock truck.
ayoslickxd
295/70/18
for sure fit cause i had 305/70:18 with no rub unless off roading then turnjng tires i would scrape
CalvinC
Colorado
You cannot go wider than ~11.6” on a stock rim, regardless of height, so that’s why 295/70/18 is the consensus.
There is one guy here who runs a 35” stock but is able to do so because he ran a 285/75/28, and NOT the traditional 35x12.5”.
I can’t recall who that member was or if he off roads a lot, but I think he said that required a bit of heat gunning but no major cutting.
Dewey
WI
295 is the widest I would go on the stock rim. Mine clear the upper control arms but wouldn’t want to get any closer.
limechallenger
Hmmm, I had 35x12.5x20's on stock wheels on my 2014 Ram, that had a level. But the tires still fit my wheels!
H2OMAN
The O.C.
This is the issue. Airing down is out of the question with this. And I don't see how OP couldn't find anything on the subject. This question is literally asked daily. Sometimes more than once.
limechallenger
OP was looking for stock suspension no level or lift! Most of the threads are guys that have levelled or lifted.
