That's why you strategically place a decal to hide the seam. I don't have MFT, but this style vinyl would hide it nicely. Obviously would need the inside edge to be solid, not distressed
me to(y)
Wiped the truck down, washed my bed (it was dusty and filthy after many T-Ball days lol), and added some reverse lights.
Of course, Bumblebee helped.
Not too crazy about them, they look like construction lights.
I’m pretty sure I have the same aux reverse lights and felt the same way after instal. Mine also took on water so I did the old “Amazon switch a roo” and sent the damaged ones back. (2 months on the truck)
Cleaned up some drone shots from the weekend. This time I remembered to remove the ND filter for night shots.
Above shows all lights on. With the "wall" it shows the XL Racers Edition Output compared to last time I did it.
Low beams and OE Fog lights only. DRL from LP6s on.
Rock Lights on with OE lighting. Looks like my truck's on fire lol
Chase Lights (BD S2 Sport) on.
LP6 Driving pattern
LP6 Full Brightness (Combo & Spot)
XL Racers Edition Only
Hope this helps for those of you who wants to put lights but don't understand which light and pattern that you need. Also shows how each light illuminates specific zone instead of just smearing light output around not putting it where you need it.
Got my Amazon personalized plates today.
My paranoia will not let me post pictures of it here so yall will just have to take my word for it. :-)
I'm sure some of you are aware, back in late 2022 Ram either had supply chain issues or they purposely deleted a few small items. One of them that I thought was necessary was the lower glove box light.
I ordered the OEM switch, which comes with a halogen bulb (dumb), so I also ordered a Lasfit blue LED. I figured the blue LED would give me an opportunity to see if wanted to change out the ambient lighting to match the blue stitching in my Lunar TRX.
I do like the blue light in the glove box, but not sure if I want the rest of my ambient lighting to be blue. 🤔
hmm i need to check that... i don't usually open my lower glove box lol
I’m rocking a blue Lasfit light in my glovebox too lol. I ordered mine completely by mistake though. After I realized I ordered the wrong bulb, I was like hey it’s actually not that bad. I’ve been rolling with it for the last two years 😂
After having IGLA and Compustar installed yesterday, it became clear how quickly and easily someone can rip out the entire set of dash panels and access the wiring behind it.
How much does that cost and how long wa sthe install?
  • air
