Hurricane ESS
Nascar Tommy
My other Ram is a Dodge.
NW Indiana.
Looking around on the 2025 build site I noticed the 3.6 V6 engine option still lists as an etorque whereas the hurricane engine is listed as an ESS.
Does this mean they are using the traditional starter motor for the ESS system?
That was the whole bragging point of etorque, not using the starter motor.
Rick3478
NW OH
Don't know the answer to your question, but that wasn't the "whole" bragging point. There are other facets to etorque, adding to engine power and regenerative braking to name a couple. I thought the way they implemented it, with a belt drive, was kinda wimpy. So maybe they've given up on the band-aid "mild hybrid", or maybe it's just too much to engineer all at once and they'll bring it on mid-year. :unsure:
Darksteel165
Massachusetts
It sounded like they dumped etorque. They should of removed start/start while they were at it.
Mountain Whiskey
For sure they are not using the traditional starter motor for this. It wouldn't last long.
Perhaps they realized that it was a bunch of electric hassle for nothing. Perhaps they realized the environmental impact mining lithium with child labor was having. Perhaps they met the green limits with a more efficient motor and just don't need it.
Darksteel165
Massachusetts
Whats the more efficient motor?
So which one is more efficient?
The one doing normal work or the other one with 20+ psi of boost getting shoved into it to do the same amount of work?
You make it sound like it's constantly going to be at max boost levels. Turbo motors don't spend a whole lot of time at max boost. And not sure I'd consider WOT in either engine "normal work".
Rick3478
NW OH
All else being equal, the boosted one with less displacement will have less internal friction. Alternately, a boosted engine of the same size producing the same power at lower RPM, but same ground speed with different gear ratios would also lose less to internal friction.
Nascar Tommy
NW Indiana.
There is still stop start on the hurricanes. Jimm07 answered. It yes it is the traditional starter motor they use but it is a heavy duty version.
Mountain Whiskey
Yes, I mistakenly thought it was in reference to the e-tourque motor that was eliminated.
