Scram1500
Thanks! I'll measure and see, drive it for a little and see if it settles.. If it bothers me, I can definitely do that. Nice feature that they are easily adjustable
I just installed the coil overs last weekend. Adjustment is super easy but tedious, at most you can do a quarter turn at a time, beer helps and so does the upgraded wrench. If I had to guess it looked like Eibach sent the coil overs maxed out at 3 inches. I dialed mine down to stock height for now until I get new tires/rims/alignment. The ride is pretty nice, smooth as stock but less jarring over big bumps, potholes, etc. Might want to think about upper control arms if you haven't already
Brunzca
St Johns, FL
Good to know, thanks... And yeah, I got the Zone UCAs installed at the same time
Ready Go
Wisconsin
This would make those adjustments more funner!!
Ready Go
Wisconsin
Since the weather in Wisco is a balmy upper-50s this week, Wifey-pooh & I have been day-trippin' around in the G/T!
Finally washed & detailed the truck yesterday, so figured today was the perfect time to stop by and take some pics at the "Old LaGrange Works Garage"...no Ethyl in the pump though🤣
Ready Go
Wisconsin
Just because you chose to waste console space doesn't mean you can't contribute positively to the conversation. 😁
The G/T still has 12 beer holders, so pretty utilitarian and a good use of space in my mind!🤣
PLUS...if you checked off the "BeerBox" Option when ordering, you get two of these!!!
