I live upstate also, I take it Krown is good protection? Got a few shops nearby and have been debating that vs Ziebarts.I live in Upstate NY and use Krown. Typically get it done twice a year but after winter, I get the Krown salt bath before application.
Everyone has their favorite. My dad is a Zeibart guy for rustproofing. I do like Zeibart for their ceramic coat and PPF. Most guys I know that have their trucks 5 years or more use Krown and have no rust issues. I've used Krown for years and never had a rust issue.I live upstate also, I take it Krown is good protection? Got a few shops nearby and have been debating that vs Ziebarts.
nice i should've done that when i did my in-cab power supply for fridge, ecoflow, and ham radio so i can hide my long gun under the seat!
I've only opened mine the traditional way one time just to see how it remotely opened.I love my MFT, one of the best options on my truck! I rarely open the traditional way. That said, aesthetically it is not the best.
Bummer.Picked mine up from the collision shop. Had a large, commercial smoker on a hefty trailer pop off the hitch not once, but twice on me a few weeks ago. SUCKED… but nobody hurt.
So after a week in the shop, got it back. Really impressed with the shop that did the work.
That trailer was one tough SOB.. a little scratch of paint is the only battle scar it endured…LOL
1000% sure.Bummer.
You sure you got the correct size ball on your hitch for the trailer?
What was your issue with the shifts and grins bracket?Installed some a pillar squadron pros in yellow from baja designs on diode dynamics brackets and a 30" OnX6 light bar with a bracket from @Shifts And Grins Fab. Had some issues with the brackets as they were not a perfect fit like advertised on my longhorn, ended up getting longer bolts and having to zip tie one part to make it secure. Was definitely a challenge getting everything in place but love how it turned out.
Wish I would of taken a picture of it, as the brackets now block it, but there is a piece of metal that is where the brackets mount. The end of it was slightly curved causing the brackets to tilt inwards when fully tightened. Ended up having to get the light bar mounted in first and then tighten the brackets fully. Puts some stress of the actual light bar i'm sure but it really was the only option. Needed to get longer bolts for this and there was an issue with the bolt threading in the bottom right hole. It looked like it tapered off to a smaller size so I drilled it out a bit to get it in halfway and secured it with some zip ties. Not too proud of the install but its really the best I could get it. I may be able to get a picture of the interference as I don't have a good way to describe it.What was your issue with the shifts and grins bracket?
Looks great man! I would agree that it looks a bit nose high. You could always drop the front down a few threads to make it aesthetically level.Had the Eibach kit installed today. Pro Stage 2. I'll get some better pics this weekend. It looks a little nose-high in these pics, but I think it's because of the sport hood, or maybe I took a crappy pic.. haha. I'll measure it this weekend, too and report back. The ride is fantastic. At least as good as stock, I also had to go over a curb when making a u-turn, and hardly even noticed that I went over it - so even better than stock there.
View attachment 177543 View attachment 177544
Thanks! I'll measure and see, drive it for a little and see if it settles.. If it bothers me, I can definitely do that. Nice feature that they are easily adjustableLooks great man! I would agree that it looks a bit nose high. You could always drop the front down a few threads to make it aesthetically level.
loose on the clamp would be my guess, In the past I would jack it up ( a little) from the trailer tongue to see if it pops.1000% sure.
2” on ball and receiver.
I believe…combo of two things. Lower hitch on my truck, bought too low…and, the lock on the receiver needed to be tightened up. We’ve towed this trailer for thousands upon thousands of miles.
I don’t think anyone has ever maintained, tighten up the trailer neck where it clamps down.
I took it all apart, springs, metal, all pieces looked fine. Gave it an additional turn or two putting it together, much more snug fit.
The dual axle trailer was designed to ride 16-18 inch high. The 6 inch drop hitch I used is at the bottom of that.
My gut feeling, since nothing inside the hitch assembly is broken or bent… between it topping out on the ball over bumps AND the receiver being loose…it was just time.
After having my boat trailer pop off the ball going out the driveway I do the same. Used to lift by hand to test till I threw my back out doing that. Jack works better. Smarter not harder.loose on the clamp would be my guess, In the past I would jack it up ( a little) from the trailer tongue to see if it pops.
