- Jul 25, 2020
If I was towing I'd use the screen that shows all the fluid temps. Otherwise, I have coolant temp and oil pressure displayed. No real need to monitor trans or oil temp while driving without a load. I like watching current mileage, I can somewhat control that. And leave trip display up for same reason I keep menu bar of left. Not really anything else I care to constantly monitorMine is very similar to yours. I don't particularly appreciate having MPG/L/100km on my screen because I can't do much about it. I only have the distance until empty on the right bar like yours. The middle display I typically leave on the screen that shows Oil Temp/Transmission Temp etc. I scroll down if I care to see my mileage and side to side to see my tire pressure. One glitch I hate about my 2019 ram is when I choose a theme for the gauge cluster/infotainment screen the theme does not stay on the gauge after the truck has sat for a while. It will only keep the theme on the infotainment system. I have to go back into the settings and set the theme again if I want it to show up on the gauge cluster again.
