Trailer 360 Cameras
MtSpaces
Hello,
In 2023 I bought a trailer 360 camera set to use with my 2023 Ram 3500. I have since sold the 3500 and upgraded to a 2024 3500 duelly.
The cameras work in either truck but do not come in through the port as described in the instruction manual, which states; select trailer/trailer cameras and select “trailer surround camera”. This option is not available in either truck but I get the “aux 1” port instead. Where this does allow a 360 view, I do not believe it allows this to function as intended.
I have discussed this with two Ram dealers and still have not received an appropriate response to this.
The cameras were over $2k never mind installation on my rv, never mind buying 2 trucks
Anyway, if you could help I’d appreciate it!
Scott
Hello,
Scott
You might have better luck in the Homepage - HD Rams forum. This is the 5th Gen 1500 Rams site.
Hello,
Scott
Your truck is not configured for the trailer surround view cameras. Did you buy both trucks that included the trailer surround view camera option (with the kit coming with the truck in a box upon delivery)?
Or, did you buy the trucks, they happen to have the 12-pin trailer connector, bought the trailer surround view kit separately after the fact, and assume it would work?
Either way, what you have pictured means that you are missing the trailer gateway behind the push to start button, and you need to use alfaobd to enable the trailer surround view camera system so the trailer surround soft key will replace the AUX 1 soft key.
Instructions on what you need to do starting in this link:
Thank you!
I like your answer, I will convey this to my ram dealer and see if it makes sense to their service manager.
Hello,
Thought you might like to hear the dealers response;
The Alfaobd is an aftermarket tool that we do not have. That is something that would have to be purchased from an aftermarket supplier.
We can try the factory tool but It wont have all the options that the Alfaobd tool has
This still doesn’t get any easier, I’ll have to make an appointment, let them try to change the setting then hook up my trailer and see if it works, if not we try again.
When I bought the second truck, I told them it had to be compatible with the cameras, don’t think this comes easy for the dealers, send like they didn’t know there was anything that needed to be configured.
Thanks again,
Scott
Hello,
Thanks again,
Scott
The dealer won’t be able to activate trailer surround view, so don’t bother with having them try.
You’re going to have to do it yourself with alfaobd, and install the trailer gateway as outlined in the thread I linked above. There are also threads on that forum that explain what is needed for alfaobd and how to use it.
I don’t suppose you live near Cincinnati, OH
I just ordered the attached meter, think I can fix it with this? Maybe I can lend it to the dealer?
Me fix this?View attachment 177003
He doesn't live near there. You will need AlfaOBD, SGW bypass, and OBD module. It was explained above.
My 2024 came with a single camera so maybe it had the gateway? I also told them when I ordered the truck that I would be using the 360 cameras so they said they ordered what it works need for the cameras to work.
Does that change anything?
Also can’t find alfaobd on Amazon, where would I get such a device
It's not a device. It's software you use with Android or Windows.
Thanks again
And here it is straight from the dealer . . .
I have reached out to see what options we have available. I have been researching and it does not look like we can add what is needed through the factory. You are correct, in it appears that the truck was not built with what is needed for the camera system to operate.
The only direction that I can point you to on your end would be to contact customer care with ram at 1-866-932-3878.
If you want to get you trailer surround view camera kit working on your truck, this is the ONLY way. Buy these 4 items:
1) Trailer gateway- 68509331AB
2) OBD Bluetooth interface VLinker MC- https://a.co/d/8QUreER
3) Security gateway bypass- Security Module Bypass | KaodTech
4) Alfaobd in the google play store for android devices, or software download for windows at alfaobd.com (no iPhone support).
Install the trailer gateway using this link as a guide:
After that is installed, send me a private message, and your trailer surround view cameras will be working like factory an hour after that.
One last question, is there a place such as a stereo installation store that knows how to do this with OEM equipment?
I only have an iphone,
Does that mean I’m sol?
The missing trailer gateway part number that needs to be installed is OEM equipment.
Right now, alfaobd is the ONLY thing that can program to add the feature to the radio.
JScan is similar to alfaobd, and can be used on iPhone. Right now, it doesn’t have the trailer surround view setting, but I can have the developer add it for you.
If you go the JScan route, get JScan obd from the App Store.
Instead of getting the vLinker MC I linked above, you’ll need the vLinker MC+.
You will still need that same bypass.
I’m sure a shop can do it for you, but they’re going to have to learn how to use alfaobd or JScan just the same as you would have to.
It’s VERY easy to use, and will take you 5 minutes to make the setting change once I tell you what to do.
Does anybody know where to get the trailer surround camera system for my 2025 Ram 1500 Laramie that has the package with 360 camera view? I went to Mopar.com, logged in and that trailer camera system is not shown for my truck. Not sure if the 2024 year system will work with the 2025 year truck.
Hey Jimmy07 and anybody else that may know for sure.
Have you any information regarding a 2025 Ram 1500 Laramie with 360 surround view option installed and if Alfaodb can be used to activate the Trailer surround view feature?
I recently purchased a 2024 trailer surround view camera system by Mopar PN 68527709AD-001 and when I plugged it into the 12 pin connector on the bumper all I see are 2 camera views when I select Aux1 camera, no surround view. When I called the dealer they said they may need to install a long digit code into Uconnect to activate the 360 trailer view camera system. Apparently this code is included into the 360 camera system I purchased and would cost me $195 and maybe 2 days with truck in the shop.
I was going to purchase the Alfaodb software, ODB2 connector but not sure if I need to purchase the gateway module, does that come with the truck when you add the surround view package?
What does the Security Gateway Bypass do?
Does this Alfaodb software also install service builtin software updates?
Is the KaodTech needed for the 2025 Ram 1500 to access all the features of the Uconnect system via Alfaodb software (if that is its purpose)?
When I had my 2016 Tacoma I used Techstream software and ODB2 connector to access the ECU module to install TSB or change configurations to the truck or install engine tunes to improve performance. It sounds like items 1-4 are needed to do the same for the Ram, correct?
First, installing 2024 and lower factory items on a 2025+ isn't going to work. The systems are different. Second, you aren't going to be able to install 2025+ factory items right now if ever. The new canbus is different. They are working on AlfaOBD, but it's going to be a little or lot longer.
I don’t think any of the 2025 1500’s can be configured for trailer surround view. It seems to be a feature listed in error on the build site. Every 2025 I see online has the AUX 1 and AUX 2 camera keys, instead of Trailer Surround and AUX 2 camera keys.
Jimmy07,
I have a 25 limited, 6-4 multifunction bed, 14.4 screen, pano, trailer brake controller, bed utility, towing tech, limited A, Surround view cams, Trailer tow group, Off road, electronic rear axle, bed utility group, tow mirrors, etc. Built 12/12/24 Software FC-MY24.U35.26-PROD
My truck has everything but the Trailer Wiring Camera Prep package (dealer told me I didnt need it, as the 12/1 way connection was already there, and it is physically present on my bumper)
I have a 10 amp red fuse present in the F62 location in the underhood fusebox, which is for "Trailer Camera", if equipped. I also have present the Aux 1, Aux 2 softkeys, but they just have the blue "camera not present" screen when pressed.
My DRVM has a cam in the CHMSL. I can press a button on the DRVM to go from truck "view" to trailer "view" with Trailer electric attached and a Visonworks 12 pin VWFD1KT, still no camera view. I get the truck/trailer icons with the yellow slash(T1 pic) The icons sure make one think you would see the trailer cam in the DRVM.
What am I doing wrong, or am I really missing the Trailer wiring prep (or is it just not enabled in the CANBUS as the XFQ option code, which I didnt order) or is it just not possible to have a trailer cam on my truck?
Dealer is useless.
Thank you in advance.
