Used Etorque Generator Programming Issue.
4JKay
So by replacing the lower section with new and reusing your original top, was this just a parts swap without any programming at all? Might be very helpful for those with failed bearings
Yep, that's exactly what I did. No need for reprogramming. So far, driven it to work with no issues. Starts up perfectly quiet. Feels alive again driving...
I took the old motor apart. There is a no computer chip boards ( on the bottom unit), Just the motor and bearings. All the computer are in the top part of the unit. That's what gave me the idea of reusing the top part, to save me the trouble of reprogramming.
Unless your unit have a bad board I would imagine you would have to replace the whole thing
Bt10
MI
Just to make the DIY people who may look into this thread aware, there is an update to the MGU to cure what sounds exactly like bad bearings - sounded like the phases getting out of sync, but I'm not an electronics guy? Anyways, mine sounded like bearings and only needed the update. One way to help diagnose is if the growling might be at cruise, but even small throttle changes would start or stop the noise.
4JKay
Yep, mine was definitely the bearings. At 1k rpm, the noise of grinding is really loud can definitely hear it in the cab while driving. On idle noise is off and on
Superbirdrag
P05192368AH is the number on the computer unit top of my MGU
05125874AA is the number on the one I just bought . Does anyone k ow if this is a part number upgrade or both are incompatable
My truck is a 2019 longhorn
Cbty2050
Should work just fine.
frisby5
To bad you didnt make a tutorial video ,in the future it would probably be getting alot of views .
