Check your lower grill before you get the light bar. You may need to replace the lower grill. My lower grill is solid so I had to get the one that is NOT solid but still has the sensors.
You are correct! I checked it last night..and solid, so new lower grill will be needed. Still have the PN you ordered?
Well... apparently I didn't solve my passenger floor water leak. It's back. I'm gonna tear into it again and solve it one way or another. Or I'll push it off a bridge.
On an unrelated Stellantis note, we traded in the ol lady's Cherokee yesterday on a 3 row Cherokee L. So far I really like it. I wanted white of course, but that was unavailable without ordering, so Baltic Gray it is.
While we were doing paperwork on the Jeep, I gave my buddy at the dealership a list of must haves for a new truck. He's gonna do some hunting to see what he can find me.
Had a wasted day! Took the RAM to my dealer per appt set up last week to have the "cold start LOUD exhaust" evaluated. Was called back 2 hrs later "Sir this is NOT under warranty as it is a Canadian built truck" ....WTH, you just figured that out? You have the vin number for a damn week? So I call RAM USA @ 1-800-992-1997. Guys were great, took info and started a case #. They said they would reach out to dealer and reply to me within the next couple of days. I was even nice to the dealer staff when I went back to pick it up by simply stating ADMIN will figure out what the deal is on this, Thanks see you soon. I thought is was really odd that my warranty book info was 3 yrs/100k KM.........kilometers?/?? thats different. So fingers crossed.
Discovered a small bubble/ glue failing on my dash a little while back, about the size of a dollar bill folded in half.
Bought some leather adhesive a couple months ago to redo my gauge pod cover that has the same issue
Glue https://www.amazon.com/gp/product/B09FF4PD4Q/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Heated the glue with a heat gun so it'd flow from the syringe for about 3 min
I unscrewed the needle from the syringe so I could pull in some glue. Tried without the needle off and no go.
Needles https://www.amazon.com/gp/product/B0B63Q7TR2/ref=ppx_yo_dt_b_asin_title_o00_s02?ie=UTF8&psc=1
Injected all the adhesive into the leather bubble
Then rolled it smooth with a MF towel under the roller. The roller is urethane and has hard edges, it will mark the leather if you don't use a towel
After rolling
Cleaned up the spot with some IPA (4:1) I have then applied some leather conditioner
Its sitting in the sun and its 60° out today so that should help cure the glue in a few hours with the windows up.
This has worked well in the past when I did my gauge pod cover but I used dap weldwood there, decided to try the Duall 88 after researching some leather dash restoration websites
Unfortunately, the warranty for Canada doesn't transfer to the US.
View attachment 175760 View attachment 175761
After rolling
This has worked well in the past when I did my gauge pod cover but I used dap weldwood there, decided to try the Duaal 88 after researching some leather dash restoration websites
i read motherf*cking towels... took me a while to realize it's microfiber towels lol
the dash looks good as new now!
Quick question:
I'm getting ready to install a powered sub. All install vids and advice I'm getting says to connect to the ANC that is under the drivers seat. Problem is I don't see anything under my driver's seat except cheerios and cheese crackers.
Do all 1500s have an ANC? Where else would it be if not under the driver's seat?😩
I'm trying to avoid going into the dash so I need to find somewhere to get speaker signal.
Quick question:
Does your build sheet list “Active Noise Control System”?
