Just getting ready to get my front bumper replaced due to the accident.
I want to eventually put a light bar in the lower grille. I understand that on my 19’ Limited that this grille has a closed backing mounted to it. I heard that it can be changed out with an open grille for this area that is open straight through and has sensor mounts.
I need one with sensors mounts.
Here is what somebody else advised me to get from another forum .
Lower Grille - Mopar (68334531AD)
Anyone actually know if this part number is for sure the open lower grille and would fit?
yes that is the correct pn# i got mine on ebay 2019-2022 Ram 1500 DT Lower Grille New OEM Mopar Genuine 68334531AD | eBay
You have far more patience for dealers than I do lol but if you can get a new battery from them, which you should, then better for you.
In the end I got it to finally start. Had to keep it on charger for 2 days and it was between 75% and 100%....then put the booster on it as soon as I took charger off and I got the truck started, barely. Had to get gas with the truck running but after a 45 minute drive to dealership due to traffic (which is normally 15 minutes) I got into their service bay and they told me to turn it off as they had way to start it. Soon as truck was off the battery indicator was on low.
It did start for them in the warm service bay...but had 8 cold cranking amps...lol
They went through the steps and called and to no Suprise to anyone, battery needs replaced. One battery replacement under warranty and voila, truck remote starts now.
Don’t worry little 3.21 truck. You’re safe from the snow in here
too clean to go outside anyways
took the last 10 amber rock lights we have in stock at the shop and used them on my own truck.
Not doing wheel well because:
1. apparently I can't count to 14 when I checked the box of available rock lights... i thought i had enough for all plus wheel well but nope I was wrong
2. I'm worried about tires hitting fender when wheeling and destroying them so...
Looks good. I've never seen the need for wheel wells. I'll admit, I don't do any hard core rock crawling, but I've never been out driving at night and needed to see the top of my tires. Am I missing something?
in the wheel well makes it a bit easier to air up and down the tires when it's dark when headlamp's dead.
been in that kind of situation a few times in the past.
I like the look....
I'm not being snarky, but I can't resist, it looks like you drove over a campfire 🔥🔥...
  • Back
