CHeYeNNe71
It happensI am kinda the same way..... But thanks for confirming that for me! Time to do a little more research and then probably **** of my wife when she sees the credit cards bill....
				Start with checking out this gallery for the different setup tire size and offset.
I'll be going 10" wide with a -18 offset which will have wheels sit slightly outside of the wheel wells.
It will depend if you go 9 or 10" wide what offset you will want. The smaller the negative offset or higher the positive offset will push the wheel into the wheel well.
Custom Offset
If you don't want rear spacers, look at Clayton Gladiator rear coils 2.5 or 3.5 and research how much lift you will actually get. Many run them on here. I'm also not sure about the towing with them, so research.
I may be missing something, but why are you getting the rear spacers? The bilsteins you are ordering (excellent choice) can adjust up to 1" on the rear shocks. That would be good for the 1" in the rear.Alright I got my plan on what I will be getting!
Bilstein 5100 0-2.6” Front 0-1" Rear Lift Shocks for 2019-2025 Ram 1500 new body style
Bilstein 5100 0-2.6” Front 0-1″ Rear Lift Shocks for 2019, 2020, 2021, 2022, 2023, 2024, 2025 Ram 1500 new body style Includes: 2 front shocks and 2 rear shocks Need a kit with assembled coilovers? Bilstein B8 5100 0-2.6" Front Lift Adjustable Coilovers with Rear Shocks for 2019-2025 Ram 1500...www.suspensionlifts.com
Forged Upper Control Arms | 3-3.5 Inch Lift | Ram 1500 (19-24)
Forged Upper Control Arms | 3-3.5 Inch Lift | Ram 1500 (19-22)www.roughcountry.com
That above will be put on first and I will eventually add these:
2-2.5 Inch Leveled Sway Bar Links 2021+ RAM 1500 with 21mm Sway Bar Nut SupsensionMAXX
2-2.5 Inch Leveled Sway Bar Links 2021+ RAM 1500 with 21mm Sway Bar Nut SuspensionMAXX Sway Bar End Links - Tighten Your Handling, Extend Your Suspension Life. Your sway bar is only as good as its connection points.Our Sway Bar End Links are built tough to eliminate flex, reduce body roll, and...suspensionmaxx.com
Lastley I will add new wheels and tires. Though that is a hole new can of worms for me.... I think I have decided on the Toyo Open Country A/T III. Wheel size and the size is unknown and confusing. I do not want rubbing or having to modify anything else, also do not really want them sticking to far out on the truck either.
You don’t gain any height from rear shocks. You’d get the height from spacers or taller coils.I may be missing something, but why are you getting the rear spacers? The bilsteins you are ordering (excellent choice) can adjust up to 1" on the rear shocks. That would be good for the 1" in the rear.
I am leaning to saying no to the spacer and finding the extra money to buy a longer spring in the back. The more I read the more it makes sense... I think I need to get a 2 inch spring to go with my 5160's in the rear. I am about to order and want to figure that out beforehand. I am also going with the 6112's up front set to clip 8 which would give a total of 2.6 in the front.If you want a proper running suspension, spacers are garbage. Sorry, not sorry. Limits up travel and doesn't limit down travel. I'll pass. People spend $30K+ and skimp on suspension, but waste money on other things.
Do you tow? If not I seen a guy running this setup on this page
Bilstein #8 setting plus Motofab .5 spacer on top which isn't going to hurt anything, plus Clayton Gladiator 2.5 Triple Rate coils along with the 5160's
Clayton Offroad 2.5" Jeep Gladiator Springs on 2020 Rebel
TDLR: The Clayton offroad 2.5 lift springs DO fit a 2020 Rebel What I tried to accomplish: I recently added Fox 2.5 shocks in the front and rear. The ORP/Rebel shocks give 1" in the back, but the Fox coilovers allow for me to go to 3" inches in the front. This means I needed an extra inch in...5thgenrams.com
Running the Gladiator coils would lessen your towing capacity, by how much I'm not sure, but it's an option. Can always use Airlift air bags in case. Some have even used the Clayton Gladiator 3.5" coils. I'm not sure if it's a true 3.5" or not.Not really.... I occasional use a dump trailer, but most of the time it is camping stuff, bikes and fishing gear going on the back.
Hey @Idahoktm, I had my dealer install this same leveling kit on my 2019 right when I took delivery on it. For the past few months I've had an increasing amount of squeaking coming from the front end when I turn the steering wheel, go over bumps, or the truck even just jostles a little bit, like when I'm getting out and stepping down to the pavement. I went underneath the truck and it sounds like it's coming from the bushing on top of the struts.My dealer installed my ReadyLift leveling kit for $387. I paid $370 for the kit with UCA's. $3900 is insane.
Interesting.... I am not really in a rush it I order what I know I need now. So I have time to figure it out regarding the coils for the rear. There are a lot of options out there....Running the Gladiator coils would lessen your towing capacity, by how much I'm not sure, but it's an option. Can always use Airlift air bags in case. Some have even used the Clayton Gladiator 3.5" coils. I'm not sure if it's a true 3.5" or not.
