Recall of High Pressure Fuel Pump
Csapp05
I'm thinking some of the confusion is trying to figure out what needs to be replaced, ie if the dealer doesn't see any metal contamination, replace the pump only. If their is metal then it turns into a major replacement parts procedure, pump, lines, injectors etc. When the CP4 pump fails, it sends metal shavings throughout the fuel system. I'm thinking the recall is hoping to replace vs repair.
Malodave
Rindge NH
There is a PDF procedure posted above, It is 131 pages, so don't hit the print button unless you really mean it.
I believe there is the pump and two fuel lines as a basic recall.
Then there is the whole Fuel System if the pump Eats itself.
Malodave
Chris3058
44.2122N, 79.4117W
Went today for a steering wheel spring noise. Get told the HPFP recall part is available late next year by the advisor. Go to waiting room and call Stellantis customer service up here in Canada. Tell them the story. They say there are lots of pumps / etc for the recall. They call the dealership as Im sitting on hold. I can hear the parts manager talking at the parts desk. Customer service dude then says ok sir the dealer has 2 and can replace it now if you’d like to leave the truck. Service advisor walks in couple minutes later looking like an angry pit viper (she is BRUTAL). She’s spitting she’s so mad and proceeds to say she read something wrong and didn’t know blah blah blah all BS and excuses. Call her out for flat out lying to my face repeatedly as this is the third time I asked about parts availability since the letters arrived and was told every time - middle / late next year. She hesitantly apologizes and doesn’t mean it. Leave my truck. Wonder what they will do to it to screw me over now. Hmmmmm. Awesome.
Brutal_HO
The Mad Irishman
Douglas County, CO
No one single emoji is relative so I'm replying. LOL
:ROFLMAO::mad::confused:(y):unsure:
c3k
Tell her you want to see the old one after the recall is complete. Because you want to make sure it was actually done. ;)
Chris3058
44.2122N, 79.4117W
Oh yeah. Old pit viper called me at 1700. Said it was all done. Sounded as happy as a wet fart. Good times. I pick it up tomorrow. We shall see. Lmfao.
Cbty2050
This isn't hard, if the truck is driven to the dealer it gets a pump. If the truck doesn't run and needs to be towed to dealer it gets everything in the system.
Chris3058
44.2122N, 79.4117W
Yeah. Exactly. My original died and I got a new original lines etc . Now they put in the new one….pump , seal and something else I can’t decipher on the parts list. Just picked it up. Pit viper was so happy to see me in all her joy she accidentally tossed the work order across the desk and onto the floor. I often wonder how dealer service departments hire service advisors…I take it they aren’t trained mechanics ? The guys in the shop were always great to talk to but the advisors - awful.
Triton63
West Michigan
Of all the different dealerships I've been to, the only time they have been nice is when I'm buying a vehicle. Unfortunately the CDJR dealer 5 mins from my house wasn't even nice then. I get a kick out of you calling her pit viper.
Notice anything different with the new pump on? Do you happen to know if they had to reflash the tune on the truck?
Brutal_HO
The Mad Irishman
Douglas County, CO
Like everything else, it varies.
My oldest was a Master Audi Tech, Master Mercedes Tech, and Lead Tech for both brands, before he moved into a Service Advisor position at Mercedes, which for him was a step to becoming Service Manager, a position he now holds - back to his roots with VW. When he was an advisor, he did have an advantage in knowing the systems inside out. He always tried to do what was in the customer's best interest, but said it was a tough job to keep the customer happy while also protecting his job, his techs, and the dealer bottom line.
askthesun
The dealer I called to book the recall said they are only allowed to order one kit per week. I was the second person to have called and book in for the 12th of December.
Have two other recalls being done at the same time aswell as front sway bar bushings (again…) they lasted a whole 15k km this time. And my rear park assist has been saying “service” since it got cold and snowy and now refuses to identify any object behind my truck.
The dealer I am using for the recalls mentioned nothing about an inspection before the recall is performed, but wasn’t sure if parts would arrive in time even when booking so far in advance. This is in southern Ontario.
Same here. Was put on a wait list, will be serviced in four months or so. Confirmed with dealer that the kit includes a CP3 pump, and dealer stated that a whole-system inspection will be conducted to assess if damage to others fuel system parts requires attention.
c3k
Did your back go out as you lunged away? Paper cuts are to be feared. Cuts, painful enough as they are, can lead to infections, gangrene, and amputation. It would be natural to have an adrenaline magnified startle reflex, jump too hard, and end up with back spasms a day or two later.
You may want to have a doctor (and a lawyer) check you out. ;)
Cbty2050
It is still a CP4 pump. That is what the sticker on the new pump says. Many people have assumed it was a new CP3 design like the one the Cummins received in its recall. The new pumps look nearly identical to the originals.
c3k
Do you know what's different about the new pumps (CP4) compared to the old ones (CP4)?
Cbty2050
I heard they made it to prevent bucket rotating and chewing itself up. But that is a rumor, nothing concrete
  • Like
Reactions: c3k
c3k
FWIW, I called my local RAM dealer to schedule my HPFP recall. (This is Z96 recall. I also need Y81, which reschedules (increases?) DEF usage.) The service department transferred me to the "Customer Relations" person. She did not answer. (Tried 5 times over 2 days.) I left a message. Supposedly she is also dealing with all the airbag recalls (other cars). So, I have no idea how long it will be for a return call, nor, once I get a callback, how long it will be until I can get the HPFP swapped.
I may swap dealers.
jhoffy22
Seems they have a system and process they're following for this.
db252
Nashville, TN
After leaving my truck for a month at the dealership, my fuel pump has finally been changed out. Good luck to the rest.
  • Like
Reactions: c3k
Denniss58
I had my fuel pump changed out last week. The day after I picked it up...the check engine light comes on. I took it in and they reset it. Something about the computer was detecting a different reading with the new HPFP and kicking the censor light. She mumbled a number when she reset it and told me to schedule an appointment if it came back on. It came back on. I will DEFINATELY get the code when they look at it this coming Monday. After reading all of these posts... I'm getting concerned . My Ram 1500 ecodiesel has 49,000 on it. It has run fine up to this point.
Sascwatch
Couldn’t get the fuel pump recall completed today as all of the parts are back ordered except for the pump itself.
Dealer also did not have the parking sensor harness in stock that my truck needs, all of the rear sensors are offline or shorted to ground or power.
And my clunking noise is the front drivers side caliper mount the figure, which is 2+ weeks out.
Headed back north with the paperwork from the dealer, hopefully the closest dealer up there will order the parts and do the repair without multiple trips.
