Idahoktm
Oh go away!
I read that in a Canadian accent, with "hoser" at the end.
Oh go away!
I don't know what you're talking aboot.I read that in a Canadian accent, with "hoser" at the end.![]()
You’re close. LOLSo about $200 USD.![]()
Thanks!Your wife has the right idea! There's just something about indoor plumbing that makes the camping experience a bit more pleasant. You have definitely nailed it with this impressive rig!
Insurance claimTook this off my dash cam. (About 11 secs) Bird doesn’t appear as big as it actually was!
Link:
Here‘s a few pics of damage. I know. Not as much as hitting a deer or anything, but it bugs me!
Yup! Filed it today.Insurance claim
Boards look great. Mine did the same on the passenger tow hook.. good times.Installed a set of Go Rhino RB20 running boards and OEM tow hooks in the past week. At first, I wasn’t sure if I liked the RB20s but they’ve grown on me.
One thing, when I removed long bolt on the passenger side to install the tow hook, water gushed out of the threaded hole. That can’t be good! Luckily, I don’t keep my vehicles too long.. hopefully it won’t Roy out before I’m ready to upgrade!View attachment 171959View attachment 171960
At least I’m not the only one! Luckily the bolt wasn’t seized.Boards look great. Mine did the same on the passenger tow hook.. good times.
Sent from my SM-G781U1 using Tapatalk
you go here:What’s the process?
I think its more of a "Red Dawn" radiator situation, if ya know what i mean.What do you top the washer fluid off with?![]()
I have a lift at home and was not pleased with the layout of my cat skid plate. I’m not real thrilled about where my lift points changed to. They seem to me to be too far back. I might be giving up the skid plate unless I can figure out a way to modify it.Had tires rotated.
Local shop wasn't bother by the cat skid plate covering some of the lift points and manage it. Great shop. Have been getting best prices and service for the last 6 years and 4 set of tires between all the family vehicles.
A member was refused thr service by a big tire chain shop due to the skid plate but is kind of understandable with big chains and their safety polocies.
There are pictures in another thread where someone cut and bent the Skeerdycat skid plate to open up the area for the left pads.I have a lift at home and was not pleased with the layout of my cat skid plate. I’m not real thrilled about where my lift points changed to. They seem to me to be too far back. I might be giving up the skid plate unless I can figure out a way to modify it.
How do I know which uconnect I have?you go here:
put in RAM, Ram, Uconnect5 click search for updates,
this page comes up and you jus follow the directions, but its basically, download the zip file, unzip it and put those files on a blank usb drive (its about 18-ish GB) - meaning these files are the only files on the drive and not in a folder.
put it in a usb port in your RAM and you'll get a pop-up asking to do the update. tap yes and it goes.
only thing that sux is you have to have the truck running the whole time and it takes like... a while... half hr maybe 40 mins mine took both times.
heres a screen shot
