Edge pulsar issues ?!
Edge is pretty good with support. They will need to get it in hand before they can give you anymore about cost because they need to make sure it wasn't damaged by user
Georgf
Russia
Ok, if you have so good expirience of Edge support i will send them my Pulsar. Thank you for suggest me.
Rebond
I had the newer Part # 32453 Pulsar on my 22 Ram 5.7 for about 8,000 miles (one year) and had no issues. I did update it with the cable I purchased separately.
Ground strap between pulsar and ECU. Always ran it in performance - MDS off with 93 octane.
I thought it was a great unit, but ended up getting an unlocked ECM and Trinity 2 for my Procharger.
I just haven't had time to sell it, so it sits in a box. I did really enjoy it while it was on the truck though.
Georgf
Russia
One more question, does anyone know is Edge cable for update Pulsar exclusive or some cheap OBD2-USB will work too?
Most of the cheaper OBD to USB cables I have found were for power only. Not data transfer
Georgf
Russia
I also assumed this, thanks. Edge could make update possibility via WiFi by a cheap OBD reader and App, but they use cable.
CalvinC
Colorado
If Edge products were as fantastic as their support is, they wouldn’t need such great support!
Seriously though, the stuff these products do isn’t that simple, and they’re not THAT prone to issues.
But I have had multiple issues with other Edge products, and every time Edge support surprised me going way above and beyond.
Pleasant surprises in service like that are exceptionally rare these days.
Georgf
Russia
Hi all. Can someone tell me in detail how to update my Pulsar? I couldn't find a video of the process on YouTube.
You have to buy the special OBD2 cable from Edge and download the updates from the website. Them connect with laptop.
Georgf
Russia
This steps I know already, thanks, but I need details, must i use Update Agent or another software, in what mode of Start button it will work, needed SGW bypass or not, step by step.
Yes, you have to use the Edge update software.
"OBDII port to USB Update Cable (Pulsar). Use this cable to update your Pulsar Product by connecting a PC laptop through USB and to the trucks OBDII port. Once connected you will need to use theUpdate Agent 1.0tool to download new updates to your Pulsar."
I'm sure one you are connected through the update agent it will be self explanatory. Otherwise, you are probably better off just contacting Edge customer support.
Georgf
Russia
Thank you, will try
Is there a reason you are trying to update it?
Georgf
Russia
Mine is throwing error codes sometimes, but i can't send it to Edge to repare because i'm not in US now. They say it was problem with ground in first products, maybe there is the reason, but i can't even open it. Just trying to do anything, to make it working without sending to Edge.
