Detroitmikeb
- Apr 26, 2023
Those of you that have the Hellwig and core ends, did you use the spacer on the bottom. The install video shows sway bar, spacer, bolt.
Yes sir.This spacer
Running the middle hole in the Hellwig.Ok cool thanks! Which hole are you running on the hellwig?
I did the Core 4x4 up/lower controls (trail/teir 3) and they are great. Plus Core 4x4 stand behind their stuff.Thanks me too. I think I’ll do upper and lower control arms next.
Go big or go home. Stiffest setting.Thanks me too. I think I’ll do upper and lower control arms next.
The Core End Links for my 2016 1500 did not come with spacers. They are built with an offset angle. It appears the current Core End Links are built straight and they use a spacer to make the offset.Those of you that have the Hellwig and core ends, did you use the spacer on the bottom. The install video shows sway bar, spacer, bolt.
The Core links had the offset until recently. The set I have from little over a year ago are offsetThe Core End Links for my 2016 1500 did not come with spacers. They are built with an offset angle. It appears the current Core End Links are built straight and they use a spacer to make the offset.
I use the Hellwig middle hole. Have considered changing to the stiffer inner hole.
I wonder if they changed the design and added the spacers for the 5th Gen Ram kit so the basic end links worked for more than one applicationThe Core links had the offset until recently. The set I have from little over a year ago are offset
Very slight.Those of you with Core's and Hellwig, does it look like your Core's come INWARD and not straight up and down?
You're gonna make me go look aren't you? The curiosity will if you don't.Those of you with Core's and Hellwig, does it look like your Core's come INWARD and not straight up and down?
Haha sorry! Mine look like the guy aboves so I guess it’s normal. It just seems like without those spacers they would be straightYou're gonna make me go look aren't you? The curiosity will if you don't.![]()
Torqued mine to 75lbs. When talking to Spence at Core, the spacers are optional.Side note do you remember what you torqued your hellwig u bolts to? Instructions say 30 but customer service said 75 and some forum members say 75. Mine doesn’t feel loose at 30 but my ride is pretty bumpy/swaying a little over bumps and it’s driving me nuts. Maybe I need the panhead
Yeah, mine seem to angle a bit with no spacers.Haha sorry! Mine look like the guy aboves so I guess it’s normal. It just seems like without those spacers they would be straight
I’m going to torque mine to 75 in the morning. I might try no spacers.Torqued mine to 75lbs. When talking to Spence at Core, the spacers are optional.
The Core Panhead bar is great as the stock one is a weak point of the truck.
