BWoody Sway Bar Links with Hellwig Swaybar
Those of you that have the Hellwig and core ends, did you use the spacer on the bottom. The install video shows sway bar, spacer, bolt.
This spacer
Ok cool thanks! Which hole are you running on the hellwig?
Thanks me too. I think I’ll do upper and lower control arms next.
The Core End Links for my 2016 1500 did not come with spacers. They are built with an offset angle. It appears the current Core End Links are built straight and they use a spacer to make the offset.
I use the Hellwig middle hole. Have considered changing to the stiffer inner hole.
The Core links had the offset until recently. The set I have from little over a year ago are offset
Makes sense why I’ve seen photos of some cores without the spacer. I think I’m going to swap mine to stiffest setting tonight and throw some car wax on them for good measure. Winter is coming.
Those of you with Core's and Hellwig, does it look like your Core's come INWARD and not straight up and down?
You're gonna make me go look aren't you? The curiosity will if you don't. 😬
Haha sorry! Mine look like the guy aboves so I guess it’s normal. It just seems like without those spacers they would be straight
Side note do you remember what you torqued your hellwig u bolts to? Instructions say 30 but customer service said 75 and some forum members say 75. Mine doesn’t feel loose at 30 but my ride is pretty bumpy/swaying a little over bumps and it’s driving me nuts. Maybe I need the panhead
Torqued mine to 75lbs. When talking to Spence at Core, the spacers are optional.
The Core Panhead bar is great as the stock one is a weak point of the truck.
Yeah, mine seem to angle a bit with no spacers.
Now that it's on my mind, I'm going to try the stiffest position and see how it handles.
I’m going to torque mine to 75 in the morning. I might try no spacers.
I know people say a sway bar shouldn’t change ride quality but stiffest was too firm for me.
