Any news yet on power fold for Tow Mirrors?
Thanks for the updates Merdas. I just placed my order for my truck. For clarifcation for others, I have a 2019 Ram limited 1500, that came with trailer tow mirrors. I've ordered an OBDLink MX+, and plan to use my laptop to connect to it via bluetooth. Here's the part numbers I ordered:
Can you follow up with exact specs of these mirror part numbers? Are they tow style mirror or just the standard? Also, where did you source parts?
If you want to install the 2021 power fold tow mirrors with cameras, running lights and trailer spot lights on any 2019+ 5th gen 1500, and have all the features work correctly, you will need driver door module 68517699AA, and passenger door module 68517698AA. All circuits are the same, and these modules have the port for the third green mirror connector that carries the running lights and trailer spot lights wires.
The settings changes are:
Doors: Power Folding Mirrors Present- YES
Doors: Tow Mirrors Present- YES
Doors: Mirror Running Lights- YES
Doors: Mirror Rear Guidance Lights- Yes
CustSetMenu 3: Rear Cargo Guidance Lights Enable/Disable CSM Present- YES
If your truck originally came with auto dimming mirrors, change these settings:
Doors: Electro-Chromatic Driver Mirror Present- NO
Doors: Electro-Chromatic Passenger Mirror Present- NO
If you have a 2021 with standard power folding mirrors, and you want to swap in the fully loaded tow mirrors, you already have the correct door modules, and you’ll make the same changes as above (power folding mirrors will already be set to yes).
So I'm having a problem finding the Mirror running lights and Mirror rear guidance lights setting in AlfaOBD. I'm new to it and running it on a laptop. When I select my truck and BCM it will connect to the 2021 Powernet for DT as it should. However there is no option for these two features in the settings. I tried to go to a 2022 and it keeps reverting back to a 2021 after it scans the truck. Any ideas? Here's a screen shot of my available Door options in AlfaOBD. I have all other features working on the mirrors, blind spot, power fold, heat, and they adjust correctly when flipped up. I'd just like to have these last two features.
After you are connected to your BCM, go to advanced mode. Drop down the BCM list and select MY2022 DJ,D2 but DO NOT click connect again. Then just go to active diagnostics, and car configuration change.
Was able to find these settings and turn them on in AlfaOBD and now I get the soft key in the radio for the trailer guidance but still no lights. The running light feature on the mirror doesn't work and neither does the little white LED on the mirror when you put the truck in reverse or with the cargo light on. Does there have to be a trailer hooked up for that light to work? And are the mirror running lights and guidance lights tied to a 2022 BCM?
I have 2019 ram 1500 Laramie with 12” screen. Power fold regular mirrors with blind spot and auto dim.
Can someone tell me what part numbers I would need for black power fold with blind spot and auto dim?
I think in another mirror thread, I saw someone wanting to trade his moose antlers for regular mirrors.
Does anyone have any clue what the third connector is on the harness for the factory power folding tow mirrors heated with blindspot? I think they might be auto-dimming since there is what looks like a light sensor on the front housing. Part number 68448076AA. I can't seem to find anything on it and the factory description lacks any detail.
Third green connector is for trailer spot lamps and mirror running lights.
Good morning,
did anybody figure out how to make the running lights and backup lights work on tow mirrors?
Thanks,
I just installed my power folding tow mirrors on my 2020 1500 limited, I also would like to know how those backup lights work. I could not find that alpha OBD setting mentioned, even when trying the 2022 selection, without reconnecting. Guess my questions are does this need to be at night, saw something that needed to hit a button on the light switch.
Do the power tow mirrors have auto dimming like the non tow mirrors? If not not a big deal but I like the feature and would love to retain it.
Also has anyone made a written guide with all the part numbers so everyone can stop having to ask?
cause I don’t think I saw the part numbers for black 2021 with heat,bsm, surround view etc or the module part numbers that work with the bsm and surround view. Or do the 2021s not need the door modules
Did anyone ever figure out the settings to enable the Reverse Trailer Spot Lights and Running lights? Have I been unsuccessful in hunting on my own in Alpha ODB for the correct setting?
I have a 2025 Limited and just swapped out the regular mirrors for tow mirrors I ordered through my dealer. Same options, so just plug and play for the most part. But struggling with these two features, as well as getting the option in the Settings menu.
Any guidance would be helpful!
sounds like another for @Jimmy07
I was able to get the reverse spottee/guidance lights configured today…finally. However the turn signals as runnings is not working
I think this was user error on my part. I think I was choosing the wrong Body Module.
I had previously tried using “Body computer: DT MY 2022+ Powernet” and could get the light settings to take.
After choosing “Body computer: DT MY 2023+ Powernet” I made the change Jimmy outlined above and all after 10 min wait they were working and the menu option for the reverse lights was visible and working.
However, still no joy on the running lights.
Here are the settings I changed:
Went out this morning and the running lights are now working. Guess the BCM need more time to reset or a few key cycles.
All functions are now working for me.
