Laramie Ambient Lighting Question
brental1
Hoover, AL
I have a Courtesy Light question. Couldn't find a thread; so am trying here. In the process of swapping Laramie seats into my 2022 BH with Level 1 Equipment Group; one (of the about 25) wires I need to add is a YL/VT from a splice in the IP to Terminal 13 on the Body side of XY330A (under center console.) This is to power the lights under the Laramie front seats (for the rear passenger area). While tracing the wires, I discovered that the Laramie donor harness for the Courtesy Lights under the IP have 2 circuits. In addition to the YL/VT (Courtesy Lamps Driver), there's also a WT/GR. Wondering what purpose the WT/GR circuit serves. Thanks, Brent
FM45
MA
The standard courtesy system in the Ram uses halogen bulbs, the upgrade Led system uses three wires to power the 2 led package. --- one for courtesy the other ambient..
-=FM45=-
jdmdc5teg06
I just purchased the kit from Paragoptics online for my Rebel which doesn't come with the wiring harness but does have the LED footwell lighting in the front.
My rebel also doesn't come with the second ambient lighting dimmer wheel by the light switch. My only dimmer dims the footwell LED's along with everything else (12" screen. cluster).
Do i need to install that second dimmer part to have both dimmer wheels? And even if I don't, do I need to still use AlphaOBD to program the ambient lighting kit from paragoptics? All videos I've seen haven't stated anything about programming the lights once installed.
Any help is appreciated.
Thanks!
brental1
Hoover, AL
Thanks!
I have a similar question. On my 2022 BH, the connectors for the 3 ambient lights are present in my truck (covered with Tesa tape). However, I have only one dimmer wheel. In addition to the AlfaOBD programming question, will I need to add wires to the connector for the headlight/dimmer wheel switch?
brental1
Hoover, AL
Thanks!
These, I THINK, are 2 of the 3 connectors (lower left of pic). These 2 were right behind the Start/Stop button, taped up to the harness. I have my IP torn up for a different reason--routing wire harnesses I have built. The 3rd connector is supposed to be behind the driver's vent; but I can't find it. So now, I'm not sure these are the light connectors.
FM45
MA
These are the connectors to look for, these a from Mouser but the OEM look exactly the same...
-=FM45=-
Ralph5thGen
HELLO EVERYONE, IM NEW THE FORMS AND HAVE BEEN READING ABOUT THE AMBIENT LIGHTING.. ITS UPSETTING THAT THESE TRUCKS ARE SOLD FOR 70K OR MORE AND ITS MISSING THESE LITTLE DETAILS WHICH WE PAY FOR... WITH THAT BEING SAID.. DOES ANYONE KNOW THE PART NUMBER FOR THE LIGHT THAT GOES IN THE REAR DOOR PANELS AS I ALREADY ORDERED THE THREE LIGHTS FOR THE DASH ?
brental1
Hoover, AL
Thanks!
Did you get your question answered about the 2nd dimmer wheel? Did you get a PN?
PM-Performance
Unfortunately there is no ambient lighting starting on in the 2021s. There are a couple of threads in here where people have added there own
I have ambient lighting on my 21 Laramie.
Matter of fact I am waiting on my 3rd replacement drive door module as mine keeps dieing for some reason on that door.
6of36
Michigan
You don't have the high line ambient they are talking about. Limiteds and maybe Longhorns, I'm not sure are the only trucks that come with it. The higher system has basically a rope light above the glove box.
PM-Performance
Ahhhh ok.
I didn’t realize the Linted has that as an extra. I just looked at a few limiteds and did not notice
6of36
Michigan
Ahhhh ok.
It's not easy to see. I can see the reflection off of the glove box door. Even when it is lit, it's pretty dim. I sure wouldn't bother fixing it if it ever burns out.
ferraiolo1
North Central PA
Yeah I wish I wouldn’t have waisted the Time and money installing it on mine.
PM-Performance
So this thread brought up more questions in life. Now I need to go out to my truck and confirm which lights I have/do not have.
I had no idea there were this many lights and I feel I am missing most of them :(
Edit: I felt like I may be missing most is because it seems like when they had the back door panels off to fix my grille rattles, they must not have set the modules back in properly. The tops and middles are super dim and barely passing light.
The front driver door is jacked because the one at the handle keeps going out, so they must have unplugged them all? The pass front door is working %100
I am waiting on 1 module for the driver door due to use. I am going to ask them on Thursday when I get my tires installed to check/reseat all my working modules and say my dash modules never worked in hopes they just add those and I’ll just add the glove box one myself.
What a clusterfuck this seems to be after reading multiple posts on ambient lights.
6of36
Michigan
I feel like my Limited has more lights than my Laramie, besides the glove box one.
PM-Performance
Honestly the only “intentional” missing ones are the dash ones. The rest the dealer either screwed up reinstalling my door panels or blew out.
Before reading this post and seeing a video on modifying the boards, I had no idea just how many ambient light modules were to be installed and were installed in my truck.
Very eye opening post as I never really looked that deeply.
6of36
Michigan
The ambient lighting doesn't mean much to me. I just noticed, with this truck, there is a lot.
