2020 Ram 1500 tail lights not working
DLK183
Hello,
I have a 2020 Ram 1500 and the tail lights (running lights) are not working, when it is dark. The brake lights and turn signal lights are working. I checked fuse F36 (Central Body Controller (CBC) 2 Exterior Light 1) and Fuse F25 (Exterior Lights 2). Is there another fuse?
Scram1500
At the risk of being "that guy" did you check the bulbs?
Edit: LED or halogen?
scotj1t
Hello,
were you able to correct the issue. I am having same problem. I just installed new LED tail lights. running lights don't work, however turn signals and brake lights do work. I put my OEM incandecent lights back in and they still work properly. I am waiting for call back from AlphaRex tech support to see if they have any issues.
ShakethThyBooty
Did you ever find out the issue? My running light just stopped working on one side. Brake and Turn signal work just fine though.
Chris Ray
I have the same issue. 2020 Ram 1500 Bighorn. Brake lights work, signal lights work, backup lights work, but neither tail lights work. Checked the bulbs, fuses, and they are all good. Happened all of a sudden. Any help/advice would be appreciated.
FUnderwood
Chris were you able to get it fixed? Mine is in the shop right now and the fuses are fine they tell me. What did you find out?
FUnderwood
Could you share what wound up happening in this situation? I just found out my running lights are not working and realize they have not worked for weeks at least! It's in the shop now but they checked the fuses and they are all fine. I'd love it if you could share what you did to remedy the problem? Thank you.
Chris Ray
No. Still having the same problem. I replaced the headlight switch and it didn't help either. I am going to try to troubleshoot the circuit board next.
Sent from my T601DL using Tapatalk
kapinallinen2
5thGenRams Supporter
Southern Maryland.
The headlight switch circuit board does nothing more than provide a voltage feedback ie."talk" to the BCM. that controls the lights.
Chris Ray
Problem solved. Even though the filaments looked intact, the small filament for the park lights was apparently broken, and it happened to both sides at the same time. I replaced the 7443 bulbs on both sides, and they are now working.
Anthony BC
I needed help,I have the same issue 2020 Ram 1500 Bighorn running lights are not working any idea?
Anthony BC
I have same issue as you i just found the issue today so and video for everyone it might help people . This video might help you
Anthony BC
Just replace the bulb it will be fine, The Reason that happened to my truck was the tail light not working, the dealership installed the wrong bulb on my truck i drove 2years without a tail light.
jackedward
Did you find anything out about the LEDs? My left LED taillight is out but I still have brakes/turn signals/right taillight. When I switch the LED Modules the left one works on the right hand wire harness and the right one doesn’t, so I’m not about to spend $500 on LED tails that aren’t malfunctioning.
