Seems like it's grounding out somewhere with that error code present.If it helps. I am getting this error code. Not sure if it correlates to my issue.View attachment 190101
B1626 is a "cargo lamp control-circuit short to ground" on my 2019 rebel.If it helps. I am getting this error code. Not sure if it correlates to my issue.View attachment 190101
were you able to correct the issue. I am having same problem. I just installed new LED tail lights. running lights don't work, however turn signals and brake lights do work. I put my OEM incandecent lights back in and they still work properly. I am waiting for call back from AlphaRex tech support to see if they have any issues.
Hello,Hello,
I have a 2020 Ram 1500 and the tail lights (running lights) are not working, when it is dark. The brake lights and turn signal lights are working. I checked fuse F36 (Central Body Controller (CBC) 2 Exterior Light 1) and Fuse F25 (Exterior Lights 2). Is there another fuse?
Go into settings on the radio and check that daytime running lights are checked !Did you find a fix for this? I am currently having the exact same issue.
There are no dedicated fuses for lights, the lights are powered from the BCM.Never did find which fuse is for the lights.
Czy masz zdjęcie tego powstania?Możesz mi się przydać. Miało to połączenie ze złączem XY400 pod siedzeniem elektrycznym.
Any update because mine are doing the same thingwere you able to correct the issue. I am having same problem. I just installed new LED tail lights. running lights don't work, however turn signals and brake lights do work. I put my OEM incandecent lights back in and they still work properly. I am waiting for call back from AlphaRex tech support to see if they have any issues.
Hello,
I had the same problem and I got fooled when I checked for power underneath the bulbs that weren’t on,no power was there nor was it at the license plate light but when I installed the brand new bulbs that were good my power returnedProblem solved. Even though the filaments looked intact, the small filament for the park lights was apparently broken, and it happened to both sides at the same time. I replaced the 7443 bulbs on both sides, and they are now working.
Sent from my T601DL using Tapatalk
