Fbird
45 minutes start to finish Without cutting the stock exhaust. 30 minutes if you cut it. The stock exhaust is worth money to some people. Especially if you have the factory black exhaust tips
not sure how your driver tail pipe comes out but there was NO joint on the drivers side...its 1 pc from muffler to the resonator. Working from a creeper builds character....lol and teaches patience....lol couple hrs. Chrome tips BEFORE.
Working off jack stands, no creeper just flat back in concrete driveway. I've done four Borla installs. Only cut one. 45 minutes start to finish without cutting. takes some precise sndling, but it comes out without cutting
Dewey
WI
I dropped the spare tire and removed the heat shield. That made things WAY easier. After jacking up and allowing the rear end to hang with jack stands under the frame there’s plenty of clearance to remove above the axle without cutting. No reason it can’t be done in less than a half hour including install of the new exhaust. I put the GT exhaust on so was essentially just like installing the one piece factory exhaust again.
No need to drop spare tire or remove heat shield. The time spent doing that isn't made up in quicker removal of the exhaust.
Dewey
WI
Either way will work. I tried both ways and removing the spare and the heat shield provided way more clearance and doesn’t add much time. The heat shield is only held on by a few bolts. It’s not like it’s a one hour project to remove and reinstall both. Under 10 minutes max if you take your time. Removing the spare tire winch bar from under the passenger seat takes up most of that.😆
L Curtis
Lewes Delaware
I considered the Core4x4 UCA, but they are so adjustable that I feel like I'd overthink it.
If you do just make sure you have at least a -12 offset because at full turn the inner tire wall can rub the control arm because the arms are so “squared”
Picked up my truck from the bumper shop. He still has to finish welding it all up and install the tow hooks. But wanted to get the truck back for the weekend
Ramroo
What are you going to use the bumper tow hooks for ?
Guy building the bumper said that the bumper is not good for using as a recovery point. The factory mounting point aren't designed to be used for that. He said to just use the hitch receiver. So basically it's just for looks to match the front bumper.
He said anyone making rear bumowrs for these trucks should include the same warning.
Ramroo
Yep, I always get a smirk when I see them.
1.21gigawatts
7-Stringer
Boston, MA
Confirmed. Once I got that piece out, which required hacking up the factory fob because it's glued in, I could start the truck with just that little chip and pushing the start button with it. The AJT install instructions do not mention this rfid chip at all, yet they have a spot for it in the fob case. View attachment 168023 View attachment 168024
sorry you had to figure that out the hard way but THANK YOU for letting us all know! I'm gonna move it over today in my AJT fob.
1.21gigawatts
7-Stringer
Boston, MA
Recovery hooks will match front bumper hammer style hooks
Leave it to a Navy guy to want the boat mooring style. 🤣 I remember almost none of my rigging/knot tying stuff from the Army 12B training... maybe like 3 knots haha. I can't remember if you have a boat or not but good on you for not being afraid to go with that style.
That's just the standard style this shop uses in all his bumpers. There is still a hole if you want to put a shackle on
Idahoktm
North Idaho
Yes, but don't hook the recovery strap to the tow ball.
