Changed the battery in my keyfob since it died in me yesterday and left the truck sitting at a gas station at 6:30 in the morning. Luckily I had my daughter following me in her car, so was able to make it to Ice Cream Cruise on time for work. Then had my wife and step son come and deliver the truck to me using her keyfob. I was under the impression we could still start the truck, even with a dead battery, because the RFID chip didn't require power. But nope.
jl13
boyle heights, CA
Changed the battery in my keyfob since it died in me yesterday and left the truck sitting at a gas station at 6:30 in the morning. Luckily I had my daughter following me in her card so was able to make it to Ice Cream Cruise on time for work. Then had my wife and step son come and deliver the truck to me using her keyfob. I was under the impression we could still start the truck, even with a dead battery, because the RFID chip didn't require power. But nope.
good to know
JamRam
This didn't work?
My fob battery seems to be on its way out as well and I had an episode of an unresponsive truck a few nights ago. Their demo worked for me without an issue.
This didn't work?
Did not work. Tried multiple times with pushing the start/stop button with remote. Each time it displayed "fob not recognized" on dash. Granted, this is an aftermarket fob.
This didn't work?
So I think I figured it out. I have the AJT keyfob cover. There is a small piece in factory fob that I didn't transfer over because I didn't know what it was. I tried my completely gutted factory fob, that only had that piece left in it and it started the truck. Now to try and get that piece out to put in the AJT fob. PXL_20230925_203037179~2.jpg
SkittleRam
CA
So I think I figured it out. I have the AJT keyfob cover. There is a small piece in factory fob that I didn't transfer over because I didn't know what it was. I tried my completely gutted factory fob, that only had that piece left in it and it started the truck. Now to try and get that piece out to put in the AJT fob. View attachment 168019
That is a realy good tid bit!
JamRam
You should try it on someone else's truck first to see if its truck specific.
That yes/no might come in handy down the road.
Confirmed. Once I got that piece out, which required hacking up the factory fob because it's glued in, I could start the truck with just that little chip and pushing the start button with it. The AJT install instructions do not mention this rfid chip at all, yet they have a spot for it in the fob case. PXL_20230925_204501797.jpg PXL_20230925_204723470.jpg
3rdrock
S Florida
I was busy working on my new truck saturday.
Front white RAM decals.
Front lower grill with air holes so I can get a behind the grill light bar. (soon)
Blue & white hood decals.
Blue trim decals.
White RAM light decals.
Removed the RAM emblems from both doors and the cheesy Limited emblem from the tailgate.
I wish they made the Limited emblems like the Bighorn & Laramie.
Diode Dynamics hitch light.
SkeerdyCat Catalytic Converter Anti-Theft Skid Plate.
Ram mud flaps.
Good Year window vents.
JamRam
Confirmed. Once I got that piece out, which required hacking up the factory fob because it's glued in, I could start the truck with just that little chip and pushing the start button with it. The AJT install instructions do not mention this rfid chip at all, yet they have a spot for it in the fob case. View attachment 168023 View attachment 168024
And just like that - my days of throwing out OEM stuff that I "upgraded" are over!
6of36
Michigan
That is the security chip. That is the part that has to be programmed to the vehicle. That chip is what makes it unique. Back in the days of key start, I buried a chip in my dash, so I could use cheap non chip keys in one of my cars.
The fob, with the rolling codes, gets programmed to the truck. Which is why I have been able to use my AJT case with zero issues until the battery died. This is just basically a "back up" RFID chip that has to be in close proximity to the receiver in the dash. Hence having to push the start/stop button with it. The regular fob, when battery is good talks to the truck in a different way
MurphBigHorn
Sorry this happen to you. But glad it did. I need to check my fob. I don’t remember transferring that chip.
I'm just glad the circumstances lined up to where I wasn't left stranded waiting on rescue, and that the truck was only 20 minutes from my house, so wasn't too much to have my wife go pick up the truck and bring it to me
6of36
Michigan
I thought you just switched cases. I would have thought it wouldn't work at all, to start, without that chip.
It does, which is how people are claiming fobs to steal trucks.
