StuartV
Lexington, SC
The new hybrids are "e-cvt". They're actually driven by dual electric motors powered by the battery pack. I much prefer the current hybrid engineering to the old style. I was ridiculed here in the past for recommending bigger batteries with a small on board engine to act as a generator. That's what honda and Toyota are now moving to. The prius is now a 0-60 6.6 second car 😂. The CRV hybrid is making 204 combines hp and 247 torque. Not bad when the torque is available immediately at the low end. The bonus is no turbo!
I have said the same thing for many years. And not just any old ICE engine onboard. If it weren't for political BS, it would be a small turbodiesel setup to run off biodiesel. All that corn they use to make ethanol should be going to make biodiesel instead.
Just look at the performance we're getting now from the EcoDiesel. A 3.0 liter turbo 6-cylinder. To run a hybrid that uses a big battery pack and electric motors to actually drive, and a small turbodiesel to charge and/or help when needed, you'd probably only need a 1 - 1.5 liter 4-cylinder. And maybe a 5 - 10 gallon fuel tank.
Set it up so you can plug it in to charge, when available, and conserve the onboard fuel. That is an EV I would be happy to own (once they got all the bugs worked out).
I'm keeping my fingers crossed that the REV with the range extender they have talked about will be some form of that - though it probably won't be diesel.
Bt10
MI
I also would favor this type of drive. Trains, and I think the Volt, are this style. Might get away with even smaller ICE, like .7 - 1 liter turbo 2 cylinder. I think diesel is allowed to keep running while fueling as well. So a range of 400 miles with 15 minutes refueling (and charging) and continuous optimum ICE output sounds perfect. Might be 200 mile range plus 30 minute charging extra at max towing? Beats looking for a charger every 100 miles like the Lightning.
Added some extra grips for back seat. More for looks than anything but they are functional. These are the gray ones. Little lighter shade than my Ceramic Gray but enough distance from the paint it's not noticeable
GP BackGrip PRO, Headrest Car Passenger Hand Grip for Truck & Car Wrangler JL JT JK Handle for Offroad, Kids & Seniors, Patented Jeep Accessories, Aluminum, Picket Grey, 2-Pack https://a.co/d/5A2uBGd
SkittleRam
CA
Well, mine is just a lowly Boat Anchor (318 LA), but it's bored 0.020" over with a Whiplash cam. I had a 440 to build, but thought it would tear my convertible in half.
318's are great! The LA head and port design is much better than the BB :)
BrandonSmith
everything honda is CVT, even the hybrid ones unless i read the spec sheets wrong lol
but if you are set on it, change your cvt fluid on time. That's the only way to delay the failure.
Agreed. I have zero issues with my CVT @ nearly 200,000 miles. I'm on the Civic forum and all the issues arise from people not changing their fluid at correct intervals or putting in non-Honda CVT fluid.
BigRedTD
Tucson, AZ
Said goodbye to the 1/2 ton. Bittersweet, but happy to be back in a 3/4 ton. Unfortunately the truck I went in to buy was sold by the time I arrived at the RAM dealer, and on my way out saw this one parked on the curb at the Honda dealer next door. 2020 2500 with 48K miles on it. Right place at the right time!
All the chrome removed except for the wheels while I shop around for those:
I bought my last Ram from that same Honda dealer. I recognize that customer vehicle parking overhang. Love the new truck!
wegasque
Goodyear, AZ
Actually, the 2023 Honda Passport has a V-6 with a 9-speed tranny
