titan3636
Yes I’d like to know this too. Is there an aux button option for ram air equipped 5th gens ?
Welcome to the forum.I am a new member but have read the form and used search feature, I have 2020 ram 2500 tradesmen with factory bed light I would like to turn off the bed lights when opening the door, only want to work when I push the button is this possible with alphaobd, I ordered the cable from koadtech and have the program
Not for the 20's and newer. Worked on my 19, but not on this 22. Its in the computer, has to be deactivated.Not sure of your other stuff but YouTube the seat belt chime it's a sequence of ignition button then buckling and unbuckling the seat belt. Not an Alfaobd thing.
Seat belt stop worked fine on my 22 Limited.Not for the 20's and newer. Worked on my 19, but not on this 22. Its in the computer, has to be deactivated.
Post in thread '2023 disable seatbelt alarm?'Seat belt stop worked fine on my 22 Limited.
Can't be deactivated using AlfaOBD on 5th Gen 1500 Rams.Not for the 20's and newer. Worked on my 19, but not on this 22. Its in the computer, has to be deactivated.
Same with 2019+ HD's, has to be the seatbelt hokey pokey. Can't be done with AlfaOBD.Can't be deactivated using AlfaOBD on 5th Gen 1500 Rams.
I did some Google searching. 21s seemed to still work. 23s didn’t. And 22s seemed to be 50/50. Could be maybe a tweak to a setting pushed out during a software update. I dunno. I’ll try the sequence again. I also found a YouTube video of a 4th Gen and Alfaobd disable. Maybe the process is the same.
AlfaOBD can’t even disable the seatbelt chime on any 5th gen cluster type.
Seatbelt trick works on all model years and instrument clusters except the new 12” digital cluster.
Witech can disable the chime on the 12” digital cluster via dealership or aftermarket user.
I’m sure the new 12” digital cluster has some type of manual sequence to disable the chime, but just hasn’t been figured out yet.
It worked on my 2023 but I had to buckle/unbuckle 5 times instead of 3 times. It works! Just play around a little.Not for the 20's and newer. Worked on my 19, but not on this 22. Its in the computer, has to be deactivated.
The seat belt indicator will always be on. There isn't a way to disable it.5 worked. Seatbelt message still shows up on the dash though.
Anyone have the info for the in cab inverter and the bed lights?
Pressing the two outermost keys does not work on my 2023 Ram 1500 Laramie. Just tries to move one of the icons no matter how I try to press and hold them at the same time. Did I miss something? Is there another way to get to this info?Press and hold the two most outer soft keys on the screen
This will bring you to Dealer Mode.
Press System Information
Press Radio Part Information
That is where you verify.
Figured out the cab inverter. I had everything right, just needed to add the fuse (F60) in the cab panel under the steering wheel. I couldn't find the specific fuse anywhere in town and the stealership had to order them, so I have a jerry-rigged fuse holder for now. I also found the bed lights settings with the help of the software people.5 worked. Seatbelt message still shows up on the dash though.
Alfaobd is an app for Android and a program for Windows.Any recommendations for which OBD2 connector to use. The prices vary so much. Also will Alfa work with the Zurich 15 from Harbor Freight?
The Zurich is a handheld scanner... So no it's not going to work.
Almost any ODB2 Bluetooth should work. Mine was $14 off ebay from around 2008 and it works fine.
