Darksteel165
Mine does.The cheap adapters don't connect to all modules.
Just because it's cheap doesn't mean it's garbage. Well maybe now it does?
Just for one example, try to use your adapter to connect AlfaOBD to the climate control module, and let us know the result.Mine does.
Nada.Just for one example, try to use your adapter to connect AlfaOBD to the climate control module, and let us know the result.
Alfa let's you connect to them just fine if you have the right OBD adapter and not a cheap one. The MX and MX compatible ones work.I didn't think Alfa could even connect to those modules, my Micropod can connect to them though.
Interesting.Alfa let's you connect to them just fine if you have the right OBD adapter and not a cheap one. The MX and MX compatible ones work.
I’ve done it, but with jscan so it should work. Make sure you go into your trucks radio settings and enable the DRLs in there too. Otherwise you’ll never see themHello
I am new here and I have did some research for my problem, but seems I did not find a answer for it.
I have ram rebel 2022 and I am trying to like this guy in the youtube but it seems does not work. is there something I need to do or like is there specific version for that mine did not work.
Only if you remove your telematics box.Hi all,
Read thru the thread, but just to understand the general consensus, you can’t add off road and performance pages to a Uconnect 5 truck??
I have a 22 ram Big Horn with 12” screen.
Did the Turn Signal DRL make the top and bottom amber? Kinda looks like the top is still white.I’ve done it, but with jscan so it should work. Make sure you go into your trucks radio settings and enable the DRLs in there too. Otherwise you’ll never see them
What exactly are the "White Frost Brows"??Turn off the white frost brows (upper and lower) on the OEM LED reflector (Big Horn/Laramie) headlights:
CBC Extern Light Calibr: Signature Light Present- NO
A made-up term. It is the signature lights on the top and bottom.What exactly are the "White Frost Brows"??
Looks like he still has the signature lights enabled. Only the Limited and TRX have amber in top and bottomDid the Turn Signal DRL make the top and bottom amber? Kinda looks like the top is still white.
Just TRX, not Limited.Looks like he still has the signature lights enabled. Only the Limited and TRX have amber in top and bottom
It's just the angle.Did the Turn Signal DRL make the top and bottom amber? Kinda looks like the top is still white.
No it doesnt. The original white lights are the signature lighting. They are always on regardless of the DRL setting. Here's @5thgen.ram 's truck. It's easier to see in this picture.Did the Turn Signal DRL make the top and bottom amber? Kinda looks like the top is still white.
