OP has a 2022 Limited and the thread is titled "Does the RAM 1500 have autostop?"
What I linked is relevant
Obviously none of the features are foolproof and can not be fully relied upon to prevent hitting anything but with that said...
If OP has all his features enabled (by default they are) going over 3mph forward will stop him before he hits something going forward via FCW.
Going backwards under (I believe 20mph) parksense would stop him from hitting something.
You can disable the braking for the front FCW to alert only, if you also disable the alert it puts a warning light on your dash 24/7.
You can disable the pedestrian breaking in the same menu as above and it generates another warning light on the dash 24/7
You can disable the rear breaking assist via park sense. You can also disable the front and rear park sensors via the switches below the radio.
This is incorrect as OPs 2022 Limited has FCW which would stop him from running into a bush at over 3 mph or higher per the manual.
This is correct, but it will stop going forward if OP is going 3 mph or higher via FCW regardless of what feature you want to call it, his 22 Limited has it.
This is incorrect, the manual states 3mph and above FCW will take over, which OP's 22 Limited would have.
This is also incorrect, see the above.
This is incorrect, going 3mph would allow FCW to engage, and stop the truck unless it was disabled and set to alert only.
These are incorrect assumptions, Ram clearly states it would stop, and to disable it per the manual if off-road to prevent unnecessary warnings\stopping.
