Does the RAM 1500 have autostop?
FLiPMaRC
NJ
It won't stop going forward automatically with ParkSense. That is absolutely not part of the system. Backing up is, but not going forward. You can test this by putting a cardboard box in front of the truck so the sensors register that it is there and then creep forward. It will hit it and push it, but it will never stop.
Not going to argue with you.
My truck has automatically stopped a few times when it sensed a bush or a fence when going forward at slow speeds.
And I don't have the "Safety Group".
vincentw56
I'm not arguing, just stating facts.
You must have the only one then.
cskindt
SW IA
How slow is slow?
Dewey
WI
Anybody wanna drive into your closed garage door and test this out?🤔
Dewey
WI
I've several people talk about running into their garage wall with the truck. So...
Yup. That’s why I question if it works on every truck. I don’t believe it’s standard and is part of another safety package.
vincentw56
Well, as I explained above, ParkSense does not support stopping while going forward while parking. But in 2021, they added the pedestrian emergency braking while you are going over 7 mph. So, I guess if you want to try running into your garage wall at say 10 mph, it should try to stop you. But under 7, it won't for sure
Dewey
WI
But Pedes
But Pedestrian Emergency Braking is part of this package. I haven’t seen anywhere it’s on all trucks.🤔
Darksteel165
Massachusetts
As far as I know tracking doesn't work on non-moving objects. ACC can drive into a stopped car in theory per Ram's documentations.
If they are going faster then 7mpg I would think it would drive right in as parksense would be disabled.
I know whenever I back into my carport lately it beeps to tell me parksense is not available because I am going too fast, but not sure on the speed I hit.
I'm pretty sure on 2022s it's clear the braking only applies in reverse as you stated with parksense (as I have it disabled) I might need to see if I can find it and snap a picture.
vincentw56
That's not true. Watch the posted video, it even mentions that the FCW can be triggered by other objects. I don't know of moving over passes or street signs.
Darksteel165
Massachusetts
It beeps when a car is turning in front of me and I go around them. Never beeped when I went close to a car on the side of the road (in the lane).
2001gw
Ocala, FL
2021 Ram Limited.
I just read this thread and decided to look up my window sticker. I have the following listed on my sticker: ParkSense® Front and Rear Park–Assist with Stop
So, I 'assume" it will stop backing up and going forward. I have had it stop backing up but never going forward. I will try the "cardboard box test" tomorrow.
vincentw56
2021 Ram Limited.
I just read this thread and decided to look up my window sticker. I have the following listed on my sticker: ParkSense Front and Rear Park–Assist with Stop
Let's us know how it goes. I'd love to be proven wrong. Could you imagine being off road in bumper tall grass and your truck stopping every time you try to pull forward? I've been there. It beeps red at me, but NEVER stops. Of course, I was only in it for about 20 seconds otherwise I'd have to turn the front sensors off or it would drive me nuts.
Darksteel165
Massachusetts
2021 Ram Limited.
This is listed in my build sheet for my 2022
ParkSense FR/RR Park Assist w/Stop
I also have that feature where it will park itself, but. Never used it though.
Trippi
Macedon NY
that would have saved me coming in hot and ramming the electrical outlet through the drywall :ROFLMAO:
vincentw56
T
I have the exact same on my truck. Also, have the park assist. Works great for parallel parking. I played with the perpendicular parking, but never really used it. Of course, I added it after I bought the truck.
6of36
Michigan
Park sense front. Rear park assist with stop. It only stops backing up. Collision avoidance will apply brakes at speed, not below 5 MPH.
vincentw56
There are a lot of calculations that happen. Things like how big is the object, how fast you are coming up on a stopped object, are you pressing the accelerator, and if so, how much. There are others also. But if there is a car stopped at a stop light and you are accelerating up to it and the system doesn't think you will stop, it will engage. Thinking it only works for moving objects is completely false.
