No Tailgate Ajar Warning (MY22)
frisby5
Looking at the schematics, it’s the same operation as the hood latch:
It’s looking for about 1700 ohm resistance when the tailgate is closed, and open circuit sets the tailgate ajar indications in the cluster.
So, if you enable the two settings in AlfaOBD, and if your cluster is capable of the feature, it will show the tailgate ajar indications since there is an open circuit from not having the correct wiring or latch
This is a known working/programmable fob for the 5th gen 1500’s:
AlfaOBD can’t program the fobs, but I can set you up with a way to program them yourself if you want to PM me.
Ok thanks ! Let me check my bankaccount lol. im looking at doing the brake controller to soon. Thats a good price for the fob on ebay..
FLiPMaRC
NJ
Anyone know how many FOBs can our trucks be programmed with at the same time? It there a limit? My Pathfinder has a limit of 3.
6of36
Michigan
I believe I read 4. Could be higher, but I know it's at least 4. Look farther down, Jimmy said 8.
6of36
Michigan
That's an amazing price!
22Ram1500InAR
Rogers, AR
Can I buy one FOB with tailgate open (for myself) and will the other two still work? I’d hate to have the others deactivated.
FLiPMaRC
NJ
How much are you guys paying to get these FOBs programmed? And where did you go (dealer/shop)??
Jako
Borough of Parks
FYI - one option in NJ
FLiPMaRC
NJ
Thank you! It's about 1.5hrs away from me. I'll search around locally. Bookmarked the post (y)
22Ram1500InAR
Rogers, AR
What do you all do with left over wiring harnesses?
I have a few--LED bed light install, headliner from installing intermittent wipers, tail gate from installing tailgate ajar. The clips are damaged or a few of the clips are broken. Ends and wire are still fin
darrell585
Anyone tried this on a 2500? Parts the same? I have the 22 Laramie 2500. I can drop tailgate with my key fob or a button on the truck. Bed lights/cargo lights do not come in when tailgate is opened. No tailgate ajar warning. I enabled it in Alfa but haven't had the opportunity to check pin 26 yet. Thanks in advance!
Jimmy07
Honorary Site Supporter
Won’t work for an HD Ram. There is no such tailgate latch part that has an ajar sensor for the HD’s, and a 1500 latch won’t fit.
darrell585
Thank you, I appreciate it! Wondering now if the BCM has the pins for it and it's in the software then I could set up my own switch.
DublDeuce
Hey all, any instruction for programming using a JSCAN? Also, how do you know if you have a small screen? My Build Sheet says Instrument Cluster Theme Level 1. I'm guessing I'm good to go to do this mod, except I just use JSACN.
Sigfla
Curious as well. I can see the tailgate ajar option but no F pin 26 on JScan.
CBC Config I/O: Connector F Pin 26 - Set to Yes
ECUConfig 4: Tailgate Ajar Indication - Set to Yes
Sigfla
Ok so JScan says it’s these last 2. Look for “Ajar.”
