Question for 33 gal. owners
HemiDude
Ohio
1/4 tank of 33 gallons is ~8 gallons, but we all know the gas guage doent read in exact inrememts, and you will never get 33 gallons into the tank if it gets to E. The truck would barely notice 30-50lbs of static weight. At least not that you would ever be able to measure without going to multiple decimal points. And you weren't only one talking about added weight of a full tank. You just happened to be the last comment that I replied to. So not picking on you specifically.
Oh I’m not feeling picked on at all 🍻
Darksteel165
Massachusetts
Damn, you have a fat pig. That etorque must add a bunch of weight. My 2020 Built to Serve weighs 5700lbs without me in it.
Of courses that was before the new front bumper.
I think it's also because I have all the fixings except trailer controller and tow mirrors.
I would guess eTorque is under 200lbs including the battery pack, MFT is likely more
Probably with the ramboxes and MFT.
6of36
Michigan
Not sure how much weight Ramboxes take up. The boxes themselfs are plastic.
It's hard to say. The top of the bed is wider, but the bottom is narrower. Different structure. You would really have to weigh both beds.
dannydyn
Connecticut
My 1500 weights more then 6,000 even without me sitting in it.
33 gallons of gas weighs around 200 give or take a little depending on the temperature...
If I fill up only to a half a tank I can go from 6360 to 6260. It would make no difference
You ordered an fully loaded Rebel. You can forget getting any kind of good mpg, that will get even worse then my Limited. Wrong choice of truck if you were concerned about gas. Maybe cancel and re-order a Bighorn or Tradesman with no features (as those add a bunch of weird way more then a fuel tank).
I'm fully aware of what I ordered. This thread is not your run of the mill MPG whining session. I just wanted to know whether other owners who live in populated areas with gas stations all over the place topped off on every fill up or not. It was more about lugging around 2 months old gas than the price of gas. It's the rational of topping off and barely driving the truck vs. filling half tank as an example, and driving on fresher gas. as for MPG consumption, I couldn't give a rat's a55 about it, or else I'd have a Tesla on order instead of an off-road trim half ton truck, now wouldn't I?
I'm fully aware of what I ordered. This thread is not your run of the mill MPG whining session. I just wanted to know whether other owners who lives in populated areas with gas stations all over the place topped off on every fill up or not. It was more about lugging around 2 months old gas than the price of gas. It's the rational of topping off and barely driving the truck vs. filling half tank as an example, and driving on fresher gas. as for MPG consumption, I couldn't give a rat's a55 about it, or else I'd have a Tesla on order instead of an off-road trim half ton truck, now wouldn't I?
Just fill up when you need gas, and drive it until it needs gas. No need to worry about long the fuel sits in the tank, unless you are talking over a year. Since you still drive it regularly, albeit low miles, I'd be more worried about the oil than the fuel. Without longer drives to get engine up to operating temp and staying there for a while to let the evap system do its job, the oil will have higher contaminants in it. Probably wouldn't hurt to do 3k mile oil changes, or every 6 months, whichever comes first.
dannydyn
Connecticut
Thank you for the input. Appreciated.
bigdodge
Happy Ram Owner
should have started a poll
6of36
Michigan
I can't find the weight, but dimensions are pretty close
Those aren't even dimensions, they're references to the dimensions. Just for instance, W116. Even if it was centimeters, 116 is 45.6", not near the width. I imagine both would have to be the same overall height, width, and length, but structure would make different weight.
