- Jul 25, 2020
It's not saying he is empty.DTE is not going to say you are empty with a quarter tank left.
26 gallons of a 33 gallon tank is over 20% still remaining, not 20 miles.
Jealous.....I drive 72 miles each way.....I live less than 2 miles from work, have about a half dozen or so stop signs and 2 stop lights. i barely ever get up above 30mph.
Yeah , I went through the same thing years ago when I got my truck in. Lifted the truck up at work (worked at a local Mopar dealer for a few years) and it was easy to see the tank was longer the standard tank.So I've had the truck a little over 2 months now. Still haven't hit 1k miles (I have a very short commute, but still drive it everyday)
I've been topping off before I hit a half tank. Yes, I'm one of those peoples.
So I havent realized until today when I drove into the gas station with '20 miles to empty' on the screen. Filled the tank and it stopped somewhere at 26.2G. Tried going 2 more times before it would click off instantly with the pump.
Previous rams I could get about a gallon more above the actual tank size, maybe keeping some in the airspace or possibly fill tube.
Either way, there's some missing space here...
whats the possibility I got a 26g tank instead of 33g?
I did not pay for the upgrade to 33g. I regretted it after my september order, but quickly found out because of my bed size it might come standard anyways, and the window sticker reflected the 33g size when it went into production so I was happy.
How can I tell what actually is in the truck?
Filled up with 10 miles left on the range and needle was just below empty. Still can’t get over 30 gallons in my 33 gallon tank. Seems to be the norm with mine.I ran mine below zero on the range with the needle below empty and still couldn’t get over 29.5 gallons. Must have a heck of a reserve or the fuel gage just isn’t accurate. Figure I have enough gas to go another 50 miles when it says I’m out.
On the bright side if you run out of gas with these trucks your really not paying attention and probably deserve to be stranded.
That's perfect.Filled up with 10 miles left on the range and needle was just below empty. Still can’t get over 30 gallons in my 33 gallon tank. Seems to be the norm with mine.
There is no way there is no way there are "2 or more" gallons of gas after the tank runs dry and shuts the engine off.Even after the tank runs empty enough that the engine dies, there is probably 2 or more gallons in the tank. The pick up tube can only pick up so low in the tank.
Is my math off $3 10 per gallon?Filled up with 10 miles left on the range and needle was just below empty. Still can’t get over 30 gallons in my 33 gallon tank. Seems to be the norm with mine.
I recently took a trip to Houston, and actually saw less than $3 a gallon. I just checked Gasbuddy, since typing my first sentence, and one of my favorites saved, for a common trip I take, is $2.97 in Auburn Hills, Mi.Is my math off $3 10 per gallon?
Your math isn’t off. If I go one county over to the metro area that sells reformulated gas it’s $3.49.Is my math off $3 10 per gallon?
We’re around $3.59 in the Tampa Bay area.Your math isn’t off. If I go one county over to the metro area that sells reformulated gas it’s $3.49.
haha I've honestly never heard this one. kinda surprised honestly.Why hasn't anyone said "You need gas on the tank to keep the pump from overheating and burning up"? Like the parts in gas vapor are going to get hot and melt without catastrophic conciquences.
I just tend to hear this in every thread like this.
I think most of the population runs less than half tank anyways so im sure if this was a concern it would be all over the boards
The argument that gas cools the pump is in a bunch of threads in this forum. It is hilarious as some think that is the reason you have more gas when it reads empty.haha I've honestly never heard this one. kinda surprised honestly.
