Insanity
That’s a great idea with the drain plug!
To me it makes sense to just have that as part of the kit. Well its not MM or BD just a cheap amazon thing. A larger volume can would be nice and a sight glass too that would be cool.
Maybe if I really really like it I will upgrade it to at least have a sight glass.
Maybe if I get a burr up my 4th point of contact I will get the bore scope out and do some looking around? See what the intake looks like.
No need for a sight glass, just check it regularly. It's simple to empty with the drain valve. I check mine about every 2k miles, when I check my oil. Usually get about 1 oz for every 1k miles. Same thing with larger volume. Unless your collecting a lot more crap than the average person.
Insanity
It will take some time to get into a habit of checking it to begin with. The rest is just to nerd out. Well the bulk truck I drive at work has a few sight glasses so I am partial in that manor.
If you check your oil between oil changes, which you should, just empty it when you check your oil.
Bob.
Connecticut
Had the tailgate recall cleared and had another free sloppy oil change. I grow tired of the dripping afterwards.
Eighty
Moderator / Dream Killer
Ask for an SRT mechanic to change your oil. They’re very meticulous. I’ve never had a drop after an oil change, and everything is clean underneath.
TheLegend
Put in the Diode Dynamics HitchMount Reverse Light Kit C1R + Brake today and really am liking it I will say it’s a little loose in the hitch but it’s not going anywhere! If you zip tie it a certain way it doesn’t move around whatsoever (truthfully it only wiggles around MAYBE 1/16” anyways) but I love it haven’t gotten a shot of the actual reverse light from behind but you can use your imagination.
As you can see in my reverse cam it’s plenty bright. I’d for sure recommend!
1BADRAMLIMITED
Oklahoma
im guessing the newer rams tailgate handles have a light built in ? looks sweet
GraniteRam
Does the truck think there is a trailer hooked up? I saw in the description on their website that there might be an issue with the truck thinking there is a trailer hooked up.
eazy1500
Swapped some double D’s SS3 Sport model
Stock on the right (driveway is sloped a little bit)
TheLegend
No it does not think that there is a trailer hooked up. I was actually thinking about putting two SC2’s for reverse lights and use there wiring harness almost like shifts & grinds has for the reverse tow hooks as well.
