Mid Travel Build
Gotsboost
Hey Guys figured I would post up my you tube channel. Lots of info on a mid travel build. Still in process.
Details on the videos and up coming mods. I will be doing full testing on the stock wheel and tire package this weekend. Jumps included!
Full icon stage 3
Swar bar delete
Locked bump stops on the front
Falcon rear bump stops
Wheel spacers
TRX take offs
Intake and exhaust.
Custom frame cut bumper.
Hey guys uploaded some jumping and whoops videos on Tiktok. It performed much better then expected.
@Gotsboost
Post some pics and videos here, some of us don't have tiktok! I'm interested in your build as I wanna go a similar route with my truck
You will notice no sway bar. I don’t ever run them on any pre runner set ups. The rear bumps should work much better. Overall I was extreamly impressed. The front set up is awesome with out the bumps on. The rear is a problem but hopefully cutting the bumps does the trick and allows the shock to do its job. We will see but I’m thinking a custom king 2.5 2 tube bypass will really clean up the rear performance.
Two things that at a must in the rear. The shock stops. Grey bumpers I made out of plastic chair feet stop the shock from rotating under the frame. Then some cheap shock boots. You have to run these or the shafts will be gone very quickly .
Will be testing these guys out next weekend. Truck is working great. Been in the air at least 15 times with 0 trouble.
74D4F5D5-8C8F-4BCF-BBD0-131B988CD55E.jpeg24B1A3D6-BBB9-408E-9EF2-184C118BF93A.jpegC9455C70-F0F0-4CD6-886B-50839E430A07.jpeg
That looks awesome
In Talks with icon about testing these. Going to be a bit. Got to let the old bank account recover.
Well had a great day of testing. The front is impressive to say the least. This made a massive difference. The rear I’m still having issues however I believe the stabilitrack system is making the rear of the truck act up. Getting that scan tool deal that turns it off completely. I might do rear bump stops before the bypass.
She flys straight. Ordering rear bump stops tomorrow so I’ll get a write up on the install.
