Cup holders to small
Sportznut
This post is the ultimate in first world problems. Just go buy a freaking cup that fits in the cup holder and enjoy the beautiful truck you own and stop complaining.
Why so rude?
Obviously other people had the same issue but even if they didn't this is a freaking truck site to find answers to questions.
Some people just aren't happy unless their not.
nemecham
Seattle, WA
I prefer my 32oz HydroFlask and usually stick it in front of the center console slider, with the slider pushed all the way forward to kind of secure them. The problem is that they slide from side to side and clank against each other during turns. I usually rest my hand on top of it when turning, but it becomes a little tedious when both my wife and I have them stored in the same place. At one time, I shoved a small coat in between the two which works, but it causes issues when trying to put the water bottle back with one hand.
I have been searching for some sort of low profile organizer/larger cup holder that will sit at the bottom of the area in front of the sliding console, but have had no luck. Do any of you know what it is called? The picture below is not my truck, but at least shows the area I am talking about.
After digging through many other threads, I may have found a solution. Amazon has a organizer that slides together and fits in the bottom area in front of the console. Unfortunately I wasn't able to find the dimensions of each section to see if it will fit my hydroflask, but it may be worth a try anyways.
Could always find someone with a 3d printer to make you an insert that will fit your hydro flask. With the prevalence and 3d printers now days, shouldn't be too hard
nemecham
Seattle, WA
I might have to go that route if the amazon insert isn't the right size. I'll post an update when I get it.
AV8OR
I found the “Coleman Autoseal FreeFlow Stainless Steel Insulated Water Bottle” in 24 oz just the right size for the forward Ram cupholders.
It slides in easily and it’s secure once in the holder.
Not to big and not to small, just right.
nemecham
Seattle, WA
The lower console organizer was delivered from Amazon last night and I just got them installed this morning. The dividers are a little plyable which works to my advantage and still sturdy enough to hold my hydroflask in place without any sliding/tipping when turning. The two front open-edged slots flex by maybe a few mm when inserting the hydroflask, but that is it. I like that I am still able to lock the center console in the in the middle position (with the hydroflask in the lower console), which still gives me access to the stock cup holders as well. The kit also came with a set of dividers for the back half of the console which is a nice added bonus. I still have full range of motion with the center console with the dividers installed. Overall I am very happy with the purchase. Here are the links in case any of you are interested:
Amazon - Vehicle OCD - Lower Center Console Organizer for RAM 1500/2500/3500 (2019-2023) (Longhorn and Limited Models ONLY)
Amazon - Vehicle OCD - Lower Center Console Organizer for RAM 1500/2500/3500 (2019-2023) (NOT for Classic, Longhorn, Limited, TRX Models)
jsimon26
Great idea, I'm going to try this out. I currently have this expander off Amazon for my hydroflask. It works great for the hydroflask, but it is kinda unusable for anything smaller in diameter. I'm also not a huge fan of the added height.
nemecham
Seattle, WA
I considered one of those too. Is it pretty sturdy? I didn’t want to risk the hydro flask crashing into the 12” screen if I needed to slam on the brakes for whatever reason. As an added bonus for the divider, it holds multiple coffee cups really well. No more fumbling with 3 or 4 of them when doing a coffee run for the family. It’s been almost a couple of weeks since I installed mine and am still 100% satisfied with the solution.
jsimon26
Yeah it's actually very sturdy. I have a 12" as well and haven't had a single worry.
xcarolina
Eastern NC
I've had this one in my cab since I bought the truck. Carry a Yeti 36 oz Rambler in there and it's nice and snug.
BottlePro (1-Pack - Adjustable Cup Holder Adapter, Compatible with 32/40 Ounce Hydro Flasks, Iron Flasks, Takeyas, Simple Modern, Nalgenes, Fifty Fifty, Thermoflasks, Klean Kanteens
Sent from my SM-S918U1 using Tapatalk
Naptowner
I came here for this exact post! Same situation
nemecham
Seattle, WA
Got the dividers in and they work perfect! Thanks for looking out!
I'm glad it helped!
Dyeelitt
Don't know if this is the best place to post this but does anyone know why the front doors on the Limited have the foam inserts for insulation in the cup holders and the rear doors don't? Kind of odd unless I'm missing something.
I have a 2022 limited and have the door foam cup holders in all 4 doors.
SKT Customs
5thGenRams Vendor
5thGenRams Vendor
San Diego
