RickWaz
42.524603, -83.756544
GraniteRam
Very nice addition. Extremely bright white backup light and the 2-second strobe when you 1st apply the brakes is a great feature to catch someone's attention.
Does the truck think it has a trailer connected?
Murphy5156
I installed a MagSafe mount from ProClip USA. Actually installed it a couple of weeks ago. Ran the cable down behind the radio bezel and plugged it in down at the bottom of the console. I have an iPhone 14 Pro Max and the magnet holds very strong (it uses the Apple brand MagSafe charging puck, which you have to supply). I've hit some decent bumps and the phone has never come loose from the magnet. I use the wireless version of Apple CarPlay so I get it the truck, slap the phone on the magnet, and go. Love not having to plug in any cables.
JamRam
View attachment 156532 View attachment 156534
Would have been great if the cable was black but that's pretty neat.
Murphy5156
Couldn’t agree more…I searched for a black version but obviously Apple only makes white and other manufacturers aren’t the same size and thus won’t fit into the mount. Maybe someday Apple will offer a black one!
eazy1500
Shrink wrap it?
Is the cable built in to the charging pad. You can buy black cables.
Murphy5156
The only time you see the cable is when there’s no phone mounted. When the phone is mounted it hides the little section of white cable that is exposed.
Jsavoie
Installed a few things on the Ram
Added some ditch lights, light bar in the lower grille and the auxbeam switch panel. Still have to clean everything up and organize the switch positions but I like it so far!
1BADRAMLIMITED
Oklahoma
WHAT DITCH LIGHT MOUNTS ARE THOSE? LOOKS GOOD
Dogpatch
Coldstream, BC
Did you cut out your lower grill? What mounts did you use?
Mopar27
Woke up to my 2020 1500 dead jumped it for thirty seconds and it started right up now the check engine light is on and it’s throwing a U1267 code took it to have the battery checked said battery/starter/alternator were all good and working fine so I brought it to the dealership they said no clue we will check it so now we wait. Anyone else have this ?
Yes, happened to my truck within the first 6 months, took it to dealer, they said battery tested fine. Before I jump starter the truck, I had tried to hook battery charger up and charger said battery was bad. Has been two and a half year now with same battery and no other issues.
  • Site Vendors
