Not sure if it still works but I used to be able to lower my truck from key fob to entry exit while the truck was parked and off and it wouldnāt override and go back up to aero when you were driving. I havenāt lowered my truck to entry exit from the fob and left it like that in a while so Iām not sure if it still has that flaw
Mine is a 19 and this "trick" works. If you lower it from the fob, it usually will stay in entry exit on the next startup regardless of speed, even up to highway speeds. Its a nice trick when desired, but the truck rides like **** so its not so practical. I have the revel links so the rear is lowered a little from standard already to level it out, when in entry exit its basically on the bump stops.
Mine will go into entry exit if the speed is below 35 mph and stay there pretty much anytime under that speed. So driving through parking lots or in my neighborhood, etc im usually in entry exit. If you accelerate too quickly it will raise back up, even if you are under 35 mph, but if you are gentle with acceleration it stays in entry/exit.
This was the same as my old 2014 too. I would be disappointed if it reverted back to aero/normal at 5mph, that would suck.
