31RamIt
- Oct 25, 2021
Ah, I see.2016-2025 Mopar Battery Heat Shield 68494324AA | Mopar Genuine Parts
2016-2025 Mopar Battery Heat Shield 68494324AAparts.mopargenuineparts.com
Yep! I had my rear LSD fluid changed with factory mopar fluid and they didn’t put the additive in. After driving about 30 miles the diff sounded like it was creaking and grinding. Thankfully I was only a couple miles from the shop so I stopped back in and they added it because they didn’t know I had a LSD (it wasn’t the dealership). So yes, I can confirm the additive is definitely necessary on these rear ends with LSD!I know for fact, if you don't add additional additives on the Chrysler 9.25 with limited slip, it will not work properly. Has nothing to do with noise, but function
are you concerned about not having a battery blanket?
Oh and I also decided to paint the bolts on my wheels the same color I painted my brake calipers and some other accents on the truck - VHT Burnt Copper. Still gotta paint the chrome method logo on the center cap but I gotta take the whole wheel off for that and I don’t feel like taking these 122lb behemoths offView attachment 152936
Thanks! It wasn’t too bad, but it was still tedious removing all the bolts and putting them back in! I’m gonna be posting a tutorial how I did it on my Instagram soon because I think it was pretty clever how I decided to do itLooks good man! I’m just thinking how grueling that prep work for each bolt was.![]()
No it was the recommended stuff, I watched them do it. The shop owner is my buddy and he was a master tech at Chrysler for 10 years. As soon as I said something sounds weird he was like yep I know what it is…I didn’t know you had a LSD. He knew before I even told him I had an LSD just because of the sound. Added the additive and immediately it was fixed.That would make me wonder what fluid they filled the diff with then, may have been standard gear oil
I'm assuming the LS in your description of your lube is limited slip. Not all brands necessarily have that qualification. It's good some already have that additive. I haven't owned one long enough to have to change it in 30 years, but back in the day you always had to add the extra additive.Strange, I've never needed to add in to any of my diffs using Mobil 1 Syn Gear Lube LS 75W-90/140
Looks Sharp..Finally got around to installing the Ram AirFlow on my Limited. Complements the added GT Exhaust, but thought I would hear the intake more than I do. But looks alone added 20HPView attachment 152978
This is much more convenient than the wiring project I did for the same thing...Got the wiring harness from @VICE design installed for the reverse light LED pods I added. Not dark out yet, will take pics of how well they work later. View attachment 152984View attachment 152985View attachment 152986
