Ulster
Is your garage actually a blimp hanger?Truck arrived at dealer this morning and just picked it up, drove it home. Checked battery voltage and it was 12.8 so plugged it into a battery tender.
The more toys you have, the bigger garage you need. Mine is 54 x 44 outside, with a 20 x 43 section with a 14 ft ceiling, and 2 16 x 43 ft areas with 10 ft ceilings. I have a few toys, and a lot of junk. lolIs your garage actually a blimp hanger?![]()
Just got the truck but the multi-function tailgate looks a bit weird and improperly installed. Also often times it does not close properly even I slam the door really hard. Does anyone have the same problem?
agree take it back. It's also a good call out for others to check this at pickup.Looks like an alignment issue, take it back to the dealer and have them correct it.
I would assume this could also be a dealer install to insure it is warranted.it looks easy to be added after the fact, look at this video
you could take your truck and buy the system after, maybe the system kit is available (mopar dealer that has it stock)even tho the option is not through ordering
I keep trying to get this off of this thread, because it's not part of production, but I mentioned this is the reason I refused the truck I had been discussing here. I have since started a separate thread. The system pictured, is the accessory you buy to mount on the trailer, to get the surround view. There is also another trailer camera system that has one camera, that will show in digital rear view mirror. The truck has to have the 12 pin at the back, to plug it in to. I have been told by two dealers, it is not available at this time with Limited 1, or Elite packages. Nobody knows why. I am still trying to find out if the harness is there, to add the 12 pin outlet.I would assume this could also be a dealer install to insure it is warranted.
No I just designed, pre-plumbed etc. to add a 2nd level in case we wanted to convert it to living space above for like a RV barndominium.Is your garage actually a blimp hanger?![]()
2 months. That’s nice! I’m right behind you on the list. A limited as well. But still in “D”. I hope the 6’4” box I opted for doesn’t result in an extended lead time.Thanks again @triple_B !! 3/31 would be 2 months from order to delivery. Things can change and probably will, but that's outstanding if I even get it close to that ETA.
It shouldn't. I ordered a 6'4" mid January. Mine is built and sitting in Maryland waiting on truck transport.2 months. That’s nice! I’m right behind you on the list. A limited as well. But still in “D”. I hope the 6’4” box I opted for doesn’t result in an extended lead time.
that might be bigger than my house...I'm now convinced my 2 car garage is toooooo small!No I just designed, pre-plumbed etc. to add a 2nd level in case we wanted to convert it to living space above for like a RV barndominium.
Nothing from the dealer either on movement from Jessup to MD?You ordered recently, which means you should have yours quickly.
Those of us who ordered early get to stare at Dealer Connect updates daily showing that it is too much of a task to move a truck 45 minutes to the dealer.
My mistake, MD to VAthat might be bigger than my house...I'm now convinced my 2 car garage is toooooo small!![]()
I just got a text from Ram saying my truck is built and should ship soon even though the website updated 5 days ago saying it was built on 2/19. I'm hoping this means that it's actually about to ship or has shippedYou ordered recently, which means you should have yours quickly.
Maybe your and Djennings trucks felt bad for leaving mine behind and are waiting in MD before their final voyage to VA![]()
I agree, your truck should definitely beat mine there. It is ridiculous it's sat in MD for so long.All I know is that it better be at the dealer by 3/5. There is zero excuse for it to be a second late with how long it has sat in MD.
I've been pretty patient the whole time because there are a lot of factors that affect production, assembly, rail movement, etc. but RAM has full control over when it gets put on a truck and there are multiple trucks going to Koons daily. If there is a point in this whole process where the oldest order gets processed first, it is now.
