UnclJim
where were the weights placed ?Fuel Shok 18x9 fit. You need to be careful with the placement of the balancing weights though.
Apologies for leaving this critical piece of info out! They have to be placed on the outboard edge of the wheel otherwise they'll make contact with the caliper.where were the weights placed ?
What lugs are those?Apologies for leaving this critical piece of info out! They have to be placed on the outboard edge of the wheel otherwise they'll make contact with the caliper.
I found this out after I brought the wheels and tires home and mounted them. I removed any weights that were mounted on the inboard part of the wheel and took them back to the shop and they were able to get them balanced without issue. They've been on for about 3k miles and they ride as smooth as day one.
I had those deform on me years ago.Just because I'm still running them, doesn't mean I'm too confident in them. I've had the wheels on and off probably 10 times and they don't show any signs of fatigue, something about $30 lug nuts bother me though. They've been on my list to replace!
ZY Wheel 14mm x 1.5 Thread Size 51mm Long Set of 24pcs Small Diameter 7 Spline Drive Black Lug Nuts Closed End with 2 Keys https://www.amazon.com/dp/B071L3GCS...abc_SD9P07E0GEXGEHPD7JC2?_encoding=UTF8&psc=1
Custom Offsets shows two 5th Gen Rams on 18" Methods (317 +3mm and 305 + 0mm), so base on that, you're probably good.I would like to know as well! Im looking into methods NV 305 and double standards 0 offset if anyone knows
After much research and sending a set of Mayhem Chaos wheels back I got 18x9 -12 Mayhem Warriors. Fit with no rubbing on calipers.Working with Custom Wheels Offsets crew to find a wheel setup that will work on my 2021 Rebel.
Vision Alloy stated none of their 18” will fit.
CWO contacting Mamba, Mayhem and Luxxx tomorrow to see if their 18’s will fit and if a 3/8’s spacer will help. I’m currently looking at 18x9 -12 offset wheels.
New posting here and thank you all for the info.
