18” Wheels That Fit - No Brake Interference
Lawfin
Hey folks. There is a lot of confusion out there regarding whether certain 18” aftermarket wheels will fit in light of the larger brake calipers on the 5th Gen.
Can we start a list of those 18” wheels that fit (I.e. don’t interfere with the brake calipers) along with offset, and the model of your truck? I’m particularly interested in XD, Vision, Helo, and Ultra wheels.
PRO COMP 46 SERIES PRODIGY, 18X9 WITH 6X5.5 BOLT PATTERN - SATIN BLACK - 7046-8983. 0 Offset , 4wd Laramie with Offroad Package
18x9 Method Double Standard -12 on a 4wd Bighorn with Off Road Group. Clearance looks comparable to the factory 18 inch wheel.
Confirmed by Ultra that the Ultra 226 Machine and 283B Gauntlet in 18x9 +12 will NOT fit.
Glad to hear the Helo 900s work in 18x9. That gives me hope. Does anyone run the Helo 904 in 18x9? That’s the wheel I want. I have an email into Helo, but so far no response.
Bought them at discount tire and he told me he had these in stock and knows they will fit
Xd139
Ax202
Helo900
Helo909
As much as I love the 18” wheel with 33’s-35’s, I am hesitant. I have noticed on my factory wheels, as thought may happen, there is scoring in the barrel where the caliper is. The small clearance appears to have allowed debris to get caught between the wheel and the caliper. My real concern is with a black wheel it would stick out like a sore thumb.
Just installed XD133 today in 18x9 0 offset on '19 Rebel, no clearance issues.
^^^. Photos and what tires did you put on those ?
These method double standards fit pretty good, only down side is you do have to do a static balance IMG_0137.jpgIMG_0137.jpg
Hoping to revive this thread...any others out there install 18" wheels that didn't interfere with the brake calipers?
Bump...would love to see more examples/pics
Icon Rebounds definitely fit. There's at least one other fairly extensive thread on this:
https://5thgenrams.com/community/threads/18”-aftermarket-wheels-that-fit.24844/
KMC km535 grenades do NOT fit. Driver front caliper scored the **** out of my rim. Also: 285/75r18 maxxis razr AT fit without rubbing
Fuel Shok 18x9 fit. You need to be careful with the placement of the balancing weights though.
