Oneservant
- Sep 20, 2022
Anyone convert/exchange the rotary dial to the console shifter (ref 5th gen)?
Thanks. If it was cheap, I suspect everyone would do it. If anyone is using all of the storage space in their ram console, they've got a hoarding issue. I have ½ a dozen different hookups to my truck. Backing up a lot, I appreciate a shifter.Yesz a few people have. As mentioned, not the cheapest conversion just to have a console shifter that eliminates over half the storage in your center console
Not sure how a shifter effects your ability to back up.Thanks. If it was cheap, I suspect everyone would do it. If anyone is using all of the storage space in their ram console, they've got a hoarding issue. I have ½ a dozen different hookups to my truck. Backing up a lot, I appreciate a shifter.
That was mainly what I used all that Console space for in my last ram - carrying take out. I suppose if I had a console safe, I might miss that little bit of extra space, but I don’t and I don’t.I will gladly take the storage space over the shifter. I use the storage space a lot. Mainly when I stop to get food on trips, it gives me a place to put the bag and have it handy. I also hide a tupperware dish under there to use for garbage.
If you can't adjust to the dial within a couple of weeks, you have bigger issues with your coordination.
But I do get it, some people just like the feel and/or look of a conventional shifter. To each his own.
Changing direction often, not having to lean forward every time would be convenient.Not sure how a shifter effects your ability to back up.
Sounds like some of y'all need longer arms. Lol. I don't have to lean forward to move mine. Set your pedals closer to firewall and push steering wheel in, then move your seat upSo here's a related thought. Some of us might be happier with the rotary if it were mounted where we could reach it without having to lean forward. If all its connections are electrical, it wouldn't take that much to relocate it to the console for example, and no programming needed. Maybe move the 4WD controls, too. And if you wanted to, you could even swap the knob to a short lever.
I ran the pedals as far down as they would go, then adjusted the seat for comfort (and I like it fairly upright). Steering wheel ended up most of the way forward, and I am still maybe eight inches from the shift dial. Would be much handier for me if it were in the console.Sounds like some of y'all need longer arms. Lol. I don't have to lean forward to move mine. Set your pedals closer to firewall and push steering wheel in, then move your seat up
sportzNut, good to know you like storage space. you could use ram's bag hooks, which are designed for your food bags and you'd save on tupperware cost. or, just put the bag in the pax seat like the rest of America. either way, i could care less since that's not what this thread's about. if you can contribute to the thread with some meaningful how-to info/insight on converting from the rotary dial to the shifter, much obliged, else leave the "coordination" diagnosis to those who work in the medical field.I will gladly take the storage space over the shifter. I use the storage space a lot. Mainly when I stop to get food on trips, it gives me a place to put the bag and have it handy. I also hide a tupperware dish under there to use for garbage.
I didn't say if effects my ability to back up, only that I appreciate one because I back up. If for this reason you can't see why I'd appreciate one - all else being equal - conduct your own experiment over a 30-day period towing multiple attachments, backing up with the attachments in between other attachments, both day and night, sometimes on uneven surfaces, in tight spaces in and out of a barn or other storage place. Or build a simulation model to do so. Let me know if afterwards (1) you can see how this affects your ability to back up, (2) if you appreciate the shifter over the rotary dial.Not sure how a shifter effects your ability to back up.
You are just used to a console shifter. Doesn't mean one is better than the other, when it comes to ability to do the jobI didn't say if effects my ability to back up, only that I appreciate one because I back up. If for this reason you can't see why I'd appreciate one - all else being equal - conduct your own experiment over a 30-day period towing multiple attachments, backing up with the attachments in between other attachments, both day and night, sometimes on uneven surfaces, in tight spaces in and out of a barn or other storage place. Or build a simulation model to do so. Let me know if afterwards (1) you can see how this affects your ability to back up, (2) if you appreciate the shifter over the rotary dial.
