Horn repositioning to avoid alarm disconnect
RebelliousGt
I’ve figured out a way to relocate the horns to deter thieves from disconnecting them before tripping alarm.
That vid has been posted on this forum before, I was hoping you were going to share your solution
The solution is to remove the horns and V bracket that they are bolted too. Drill a new hole for both horns 1 1/2” up the bracket which would bring your horns up towards the upper cross member. Then re install
So you relocate the horns 1-1/2" higher. I feel like there should be more to this...
It honestly is that simple!! I should have told ram engineers.
This is the passenger side over the R both pictures taken after modifications. Look at yours and you’ll see wires.
This is from the top at the hood latch, look at your and see the difference.
Anymore then an 1 1/2” and the horns won’t have room on the V shaped bracket.
If you’re trying to see the horns in the picture you can’t really, that’s because they’re tucked up better than factory install. Otherwise you’d see more. I’m
It looks like the wires are obscured more, but can't they be snagged by a wire bent up and jacked all around in there?
They would just be guessing at where they are if you can’t see them. I also zip tied them to the V bracket. Thieves want in and out.
If Ram programmed the active grille shutters to close when the truck is turned off like my wife's car, this would be moot.
Wouldn't help me, though - I don't have active grille shutters.
