Horn repositioning to avoid alarm disconnect
RebelliousGt
I’ve figured out a way to relocate the horns to deter thieves from disconnecting them before tripping alarm.
HemiDude
Ohio
That vid has been posted on this forum before, I was hoping you were going to share your solution
RebelliousGt
The solution is to remove the horns and V bracket that they are bolted too. Drill a new hole for both horns 1 1/2” up the bracket which would bring your horns up towards the upper cross member. Then re install
RebelliousGt
Eighty
Moderator / Dream Killer
So you relocate the horns 1-1/2" higher. I feel like there should be more to this...
RebelliousGt
It honestly is that simple!! I should have told ram engineers.
This is the passenger side over the R both pictures taken after modifications. Look at yours and you’ll see wires.
RebelliousGt
This is from the top at the hood latch, look at your and see the difference.
RebelliousGt
Anymore then an 1 1/2” and the horns won’t have room on the V shaped bracket.
RebelliousGt
If you’re trying to see the horns in the picture you can’t really, that’s because they’re tucked up better than factory install. Otherwise you’d see more. I’m
cskindt
SW IA
It looks like the wires are obscured more, but can't they be snagged by a wire bent up and jacked all around in there?
RebelliousGt
They would just be guessing at where they are if you can’t see them. I also zip tied them to the V bracket. Thieves want in and out.
Eighty
If Ram programmed the active grille shutters to close when the truck is turned off like my wife's car, this would be moot.
Wouldn't help me, though - I don't have active grille shutters.
