Desert Dawg
Finally able to get a quick photo shoot of the finished suspension.
As mentioned previously, I decided upon the BDS 3-inch lift with Fox 2.5 Performance Elite Adjustable Coil-overs with remote reservoirs and dual speed compressors (DSC) paired with new BDS UCAs for the front and Fox 2.5 Shocks with remote reservoirs and DSC in the rear paired with a set of new longer springs. The system comes with the drop brackets, cross members, steering knuckles, and other hardware needed to correct the front geometry (so CV angles are back to factory angles) and keep the drive shaft aligned properly. The rear suspension geometry is corrected with control arm relocation brackets, bolt-on rear track bar relocation bracket to re-center the axle, and extended length sway bar links to correct the operating angle as well. BDS also provides bump stop extensions (limiting up travel).
Overall, I am very, very happy that I waited for this new system to finally come out. Although technically, I didn't really wait as I went through 3 other suspension systems in my attempt for the perfect setup that would achieve the stance I wanted while maintaining the truck's daily drivability and usability but also enhancing its off-road performance...lol. But I finally have a mild lift that is very strong, has the correct steering and drive shaft/differential angles, and provides plenty of clearance and articulation for 34-35 inch tires for moderate off-road use. The 3-inch lift system for the Rebel is actually the 4-inch system for the base 1500 with some hardware specifically for the Rebel.
Again, I am happy with the results as the truck does not have that "over-lifted" look that the BDS 4-inch spacer or 6-inch coil-over lifts have on the Rebel as well as keeping my raised center of gravity within reason for high speed highway driving or off-canter wheeling. The Fox shocks are fantastic although I still have to play with the adjustments to get the ride I want while in town, but no doubt will perform well when adjusted for off-roading. I took the Rebel on a road near my home that has a series of high speed bumps and barely knew they were there at high speed.
