PR40.1 Update File?
Tellsch
Does anyone have the file(s) to manually update uconnect, similar to what was provided with PR39.9?
Secondarily, one of the fixes/updates listed is "Android Auto Enhancements". Can anyone confirm what that is? Hoping for full screen AA, but I haven't seen anyone post that they have this version installed.
I'm out of warranty and the dealer wants $180 to do the update. I will do it if I know if AA goes to full screen.
FLiPMaRC
NJ
I asked on another and I don't think anyone has the 40.1 file yet.
Toperz
Stratford, CT
Hello.
Did anyone got that update? And is there difference between 39.9?
hessclark
Buena Vista, Colorado
I just updated to PR40.1 from LR34.31 and wow! It fixed my AT&T wifi issues... The sound quality of the Harmon Kardon system seems even better and the bass seems more powerful. Followed the update instructions with a flash drive and was super easy.
Toperz
Stratford, CT
Go to the link from telsch. Click on instructions and scroll down for links to files
azzx
Central AZ
I did try to update to 40.1. It did not, I did get error code 01.
what is code 01?
i am on 39.9 currently
also, do I need a 16gb flash drive for this? I am using a 8GB drive
St-na
Houston
Did You manage directly, without LR39.9? Somehow my truck is not seeing LR39.9 soft. Tried different USB drives, format, unzip all acc. to instruction. With LR40.1 no problems, but I am afraid to go directly. My current LR39.6
Edit: 39.9 was not properly unzipped, I manage 2nd attempt and now all working.
azzx
Central AZ
I maybe wrong -- I thouhgt a file needs to be deleted when the update is extracted to thumb drive. Below is the Pic of my drive content
Mdhwoods
So how the heck do you get the 12.1” into dealer mode on a 2023? Every time i try and push the corners, i push the icons, no matter how close to the corners i get. I’m thinking something may have changed.
vincentw56
You have Uconnect 5 it sounds like. Make sure you know what you are doing before you do it.
azzx
Central AZ
Thanks - update successful - so far cant tell any diff compared to 39.9
