Belvedere
Lpsouth1978
Hey, that could work. The ones that clamp to the receiver get in the way of the pin and chains. The receiver just isn't big enough.
Would you mind posting a pic showing the brackets on your truck sometime?
I'm sure I could get some this afternoon when I go to lunch.
jl13
boyle heights, CA
Thanks. I saw that, but looking for something permanent. Sometimes we take the tent and sometimes the trailer. None of the hitch mount options I've seen will work and keep the receiver usable.
I like this from diode dynamics but also thinking about giving this auxbeam set a chance and run the wire to the blazer controller. If its too much light maybe just one would be enough. I think there are options to drill or mount it in the bumper.
Belvedere
That might be a good option too. I was kinda thinking about KC Cyclones with magnet mounts.
jl13
boyle heights, CA
That might be a good option too. I was kinda thinking about KK Cyclones with magnet mounts.
might work too, think i have seen something like this install under the hood as well. good option there for people that work late on their engines
After seeing the bar mount lpsouth shared, ai started looking, and think I will try these. I like that they are blacked out when not on
: 6 Inch LED Light Bars,2pcs 60W Flood Beam 12V Small Slim Light Bar Pod Fog Light for Trucks Motorcycle Off Road ATV UTV https://a.co/d/bSjQZLd
Lpsouth1978
Those look prety slick. Wish I had seen them before doing mine. I like the 6" length of mine, but those are only about half the height and would be conceiled better.
P.S. - Pictures of the mounts under my truck should be coming in the next hour or so.
cskindt
SW IA
I got a new windshield!
It's an original equipment equivalent made by Vitro, which also appears under the OEM glass.
There was no need to re-calibrate the LKA/FCW/ACC system either. It all worked as usual with no errors.
And, as an added bonus, I received the much-anticipated UC5 v26.17 update from v26.15!
Lpsouth1978
Here are a few pics. They are not the best, but couldn't really lay under the truck in my scrubs during lunch.
20230215_132216.jpg 20230215_132204.jpg 20230215_132206.jpg 20230215_132224.jpg
JamRam
BowDown
Frisco TX
@BowDown, would you share what seat and door protectors you have? I have a Limited coming soon (I hope) and I have an even bigger shed monster, Winni!
Thank you View attachment 151870
I believe these are some recommended here by others, the seat protector is nice and thick so her nails dont go through it
  • Top
