installed TRX steering wheel into my 2019 bighorn
mike_ct
maybe paddle shift csm ? maybe I need to enable a check box on uconnect?
mike_ct
Also, now that I noticed paddle shifters is showing up in Uconnect, they are no longer functioning at all.
Jimmy07
Honorary Site Supporter
That actually might be good news. Problem is, the DT BCM doesn’t seem to be capable of having paddles with a 4pos rotary shifter. There needs to be a means of activating them, and you found it with the radio CSM. Now that the CSM is there, the paddles default to disabled. It’s just the BCM doesn’t recognize turning them on.
mike_ct
I thinking a GT truck would activate the same way? There would be a Uconnect toggle? Maybe I need a bcm from a newer / or GT truck next?
Jimmy07
Ugggh…I really hate when this forum goes into it’s spells of not sending email notifications. I have to get on it to see if there’s any reply alerts.
I’m not sure if the GT does or not. I know @Darksteel165 said he’s driven one, but if there was a radio CSM, it may have been checked yes already, unbeknownst to him.
Need to ping someone on here that has one to see if they can confirm if there’s a radio setting.
How about @1.21gigawatts, @jives, or @HemiDude ?
mike_ct
Showed up under driving/safety
mike_ct
Don’t think I saw these in my bcm. Have to double check now.
Jimmy07
P/T Chassis Net: TCM Transmission Control Module will be enabled on all ram 1500’s. The P/T Chassis Net is the canbus C network, and all of the modules on that bus that are present on the truck.
VehConfig 7: Transmission Drive Mode could be something, though, since it’s a vehicle option configuration.
mike_ct
@Jimmy07 how about a bcm swap? can I do a newer bcm or does that require a dealer trip & re-pinning some connectors?
