just sharing info with others in the group - recently picked up a 2021 steering wheel (with paddle shifters) and put it in my bighorn.
took all of 10 minutes. didn't need any special puller or tools. I used a small slotted screwdriver to put the airbag retaining ring, and a metal pick to pop the airbag electrical connectors out after seeing it done that way on a YouTube video.
End result - fits right in, no issues, plugs right in, no issues, everything works as it should. I have not made any changed via alfaobd yet. The paddles do work to change gears and are indicated on the cluster by the odometer. I don't know that it's using different shift tables or not, I'm going to log some runs with hptuners tonight and see its actually accessing different shift schedules/pressure tables than the bighorn range limiter buttons.
But end result, if anyone was thinking of getting a gt or trx wheel for their 19+ peasant trucks, you can put it right on and it's up and functional.
LOVE the flat bottom and the contoured grip area of the TRX wheel.
Only thing is, the particular wheel I purchased on eBay, is not a heated wheel, but price was right and I really wanted to mess with paddles.
NOTE: You can't really just get paddles and wire and add them to your stock wheel without modification, because there are 4x threaded screw bosses in the center casting area, where the paddles attach, and are missing from my bighorn wheel core casting.
I'll put some pics up tonight and post some results form hptuners logging when I get a change.
