Poor gas mileage
SnowBlaZR2
Fuel Economy Champion
FL
What's important to me is the fact that the window sticker stated one thing and in actuality it is false.
It's not a guarantee that everyone will get those numbers.
I regularly beat the sticker numbers when I'm not towing. Others don't.
ferraiolo1
North Central PA
Is this a lowered Rebel?
allharley has a Rebel.
Thread wasnt started by him.
And before it was lowered and I had 33in all terrain tires like a rebel. I still got around the same mpg.
I actually did the exact same trip before it was lowered but without the bike and averaged closer to 22mpg. It’s really all in how you work your right foot.
SD Rebel
San Diego, CA
While I don't doubt your mpg, it's not close to the norm of most Rebels, with quite a few Rebel mpg threads to support their less than stellar mpg.
The 33" all-terrains on the Rebel are Duratracs that are essentially a hybrid AT/MT pattern, which hurts mpg compared to most standard type A/T tires, plus they are heavy. Rebels also have the mandatory 3.92 rear axle, 1" higher ride height up front and no active aero.
I'm a guy who could squeeze almost 25 mpg out of my F150 (rated for 23 mpg), but I can barely get 15.5 mpg on the highway on my Rebel and average 12 mpg mixed city/street. The variables on Rebels just don't equal good mpg.
But, as many Rebel owners will say, I still love my truck and would have no other trim.
  • Like
Reactions: TSL
ferraiolo1
North Central PA
My at tires were Toyo open country at3 extreams. On a -19 offset wide wheel. So basically the same thing.
And per the mpg threads. The 3.92 gears get just as good of milage as the higher gear ratio.
SD Rebel
San Diego, CA
I think your variables in terms of road and conditions probably lends itself better to good mpg. Do you have flat roads in your area? Could be also you have a superior right foot when it comes to extracting good mpg.
Unless you think everyone else who owns a Rebel and complains about the mpg are wrong?
Look up real world mpg on Fuelly with Rebels vs other trims, it's clear they are especially low.
ferraiolo1
North Central PA
No, I’m in northern pennsylvania. It’s literally all mountains.
I think it’s a lot to do with riding habits
SD Rebel
San Diego, CA
Wow, it's impressive you can do that. Again, I believe you, but your example is not the norm for people driving similar trucks.
ferraiolo1
North Central PA
I can also get it to average 10mpg. Then my wallet starts to hurt.
If I left MDS and *** on it would probably average better. But with a loud exhaust that stuff gets annoying so I keep it off.
SD Rebel
San Diego, CA
I can get somewhat decent mpg, but that would mean hypermiling and angering the drivers behind me and not so much fun.
Either way, it's worth the price of admission :)
Idahoktm
North Idaho
I'm not sure why you're getting such crappy MPG's with your Rebel. I have the exact set up now (Front end leveled and Rebel wheels/tires), in much colder weather and I'm getting 15.5/16 MPG in the city. I haven't driven on the highway yet with these wheels/tires, so I'm not sure what I'll get but I'm thinking it's going to be the same as my Ridge Grapplers (18-19 MPG).
ferraiolo1
North Central PA
Pedal commander or tune?
I know when I put my pedal commander up to the higher numbers my city mpg drops a lot.
For that trip i turned it off.
theblet
What's important to me is the fact that the window sticker stated one thing and in actuality it is false. Trade in a brand new 2022 truck with 700 miles on it? Great advice......
If you read my post again, the fill issue is not a gauge issue. It seems to be some sort of venting issue that won't physically allow me to properly fill the tank the last 1/8 of the way.
Look at the combined gas mileage in my picture. You think that's acceptable based on the sticker claims?
Like others have stated, the window stick is "best case scenario". Alot of factors contribute to mpg. Is most of your driving in the city? Do you remote start your truck, or leave it running often? Do you hit alot of drive thru's? Wind will also make it worse. How much cargo do you have? What octane fuel are you running?
Personally, I like to accelerate briskly, get to speed, and set the cruise. I find it's better to make 3 mpg for 5 seconds, instead of 5 mpg for 15 seconds.
BowDown
Frisco TX
It absolutely does. There's lots of Rams in my area and I run across many at stoplights and they many will accelerate harder from a stop light that I do in city traffic and I usually pass them around 45-50mph as I don't accelerate like they do but get the truck into 7th or 8th as often as possible, in other words, I don't accelerate shifting at 3-4K RPM's and usually drive 10-15mph over the speed limit.
Trooper4
Ellensburg, Washington
Read the fine print on the window sticker. There is no place that it states that this will be your MPG. In fact, it states just the opposite.
  • WindowStickerPDF.pdf
SD Rebel
San Diego, CA
I think it's a lot of variables, including the terrain in my area, however it's still way down compared to other trucks I've owned.
The reason why I'm not worried is it's right in line with what many Rebel owners are reporting and similar to what I see on Fuelly on Rebels.
Trooper4
If we take into account the thousands of parts and the innate differences in each of them, and the thousands of combinations of those parts in the multitude of configurations of the trucks sold, and the fact that the countries that we get those parts from don't like us, it's a wonder that things aren't a lot worse than they are. We complain about the MPG, and then complain about lack of power. It's a 5000lb brick, not a Prius.
SD Rebel
San Diego, CA
Couldn't agree more, but not really complaining about the mpg of a big truck.
The Rebel thing many owners complain about is that the stated MPG is based on a "rubber stamp" EPA figure from a regular RAM with street tires. It has the same rating as a Laramie with 18" base wheels, 3.21 rear axle and street biased tires. TFL Trucks actually reported this as well when their long-term Rebel wasn't getting close to the mpg rating.
Not technically illegal for RAM to do, but kinda shady since the EPA allows manufacturers to lower EPA ratings on specific model trims. The same way Chevy lowers the EPA rating on the Silverado Trail Boss package trucks, RAM could have done the same on the Rebel but chose not to.
This wasn't an issue for me, since I'm familiar with leveled trucks on 33" tires. But there are a lot of first time buyers new to trucks who bought the Rebel and actually thought the window sticker was going to be somewhat accurate. They are usually the ones posting on these forums shocked to see 12-15 mpg in most situations.
BigD
I was getting 27 mpg the other day doing 45 mph on the freeway because we had an ice storm the night before. If I drive 55 to 60 mph on a highway I can get 24 mpg. So I am actually getting better than what the sticker says. Now if I go 75 mph on the freeway I only get 17 mpg because I got 3.92 gears. U got a Rebel which stands 2 inches higher & has off road tires. I'm sure u got 3.92 gears, not 3.21. So what are u complaining about? As far as the gas tank stopping 1/8 too soon, big deal. Mine does that at certain gas stations. is that really that big of a deal ? U actually brought your truck back to the dealer to fix non existent problems. Did they laugh at u ? Holy crap, I can't believe the stuff people whine about on this forum. That's why I barely go on here anymore. Let's talk about real problems & real solutions.
SD Rebel
San Diego, CA
Who are you specifically talking about?
It can't be me, I made it clear I'm not complaining about my mpg.
As for others complaining, it's a forum, they exist so people can discuss issues and things that they like and sometimes bother them. You are complaining about people complaining on a truck forum?
