did you check your spair tire to see if it is completly up in its position and tightI have a 2021 1500 and have the same sound as the OP had when going over bumps. My clunk comes from the right rear. I do not have air suspension. Any ideas on what else to look at? I've an oil change/tire rotation coming up , but wanted to see if I could figure it out
I did. Very tightdid you check your spair tire to see if it is completly up in its position and tight
Yes but it's removed and sounds very similar if it were mounteddo you have a trailer hitch or pin in the hitch receiver
No bed step. Will check exhaust, thanksdid you tried to shake or lift your borla exhaust, maybe with bumps it hit something? do you have the bed step, samething? when i close my bed step it hit on the resonator...
Think I found the culprit. A loose sway bar link bolt from when I adjusted the hellwig bar. Will know in the morning on the way to workNo bed step. Will check exhaust, thanks
Sent from my SM-G981U1 using Tapatalk
It was the sway bar ball link. Much quieter now.Think I found the culprit. A loose sway bar link bolt from when I adjusted the hellwig bar. Will know in the morning on the way to work
Hey there @Carlosfox15Hi, i just got delivery of my brand new Laramie 2022, with now 600 miles on the odometer it has now developed the "Clunk" behind the rear seats (mine is mostly on the passenger side of the truck), i believe that it will be the c pilar cab supports beneath the truck, i have seen a TSB around to fix that on earlier models, but i don't know if those are already updated on late 2022 models, @RamCares do you guys know if those supports are already updated on the 2022 models or if there is a TSB for my year? It is worth to know that my noise only happens on rough roads or when i hit a bump on the road at a regular speed.
i have the exact same thing going on with the same helper bags what did you do to fix this noise?I figured out the noise . I Have Rear Air lift 1000Hd helper bags and the pucks that sit on top of the bag are making the noise bouncing up and down .
What did you do to fix it i have the spacers tooThanks and it was a process, would of never let the dealer try and find that ...my wallet would of been real light after that lol
