Well, I tried to install the Vice Designs rear tow hook brackets on my truck.  These are to allow you to use your factory front tow hooks o  the rear.  Unfortunately, they will not work with the Borla tips.  Unless you want about a 2" gap between the bumper cut out and the tip.
The last picture is the gap with just the bracket installed, and the tip is hitting the bracat. As you can see in second picture, the rip will have to come down at least another inch just to get the hook on, and even more if you don't want the tip to rub.
